Results 1 to 3 of 3
Thread: Mach 3 with USB microscope for scanning
    Mar 2008
    Well I bought an Ebay USB microscope and downloaded Tormach's scanner freeware.
    I was able to have this setup up and running through Mach3 in about 2 hours total time.
    It only took a few minutes to setup and get things rolling, but I had a few issues using the software after I did their testing with a penny. I ironed it out and it works very nice. For those interested in doing scanning in 2d for checking parts, or scanning in parts to reverse engineer , this is a very fast nice setup. Looks very good so far from what I see.
    The software is $335 for a full version which then lets you export files as DXF so you can load them directly into cam software. I am contemplating this purchase because $335 is alot of money. But the ease at which this was accomplished, it might well be worth it.
    Anyone else mess around with this ?
    I didn't do this on my Novakon machine, but one of my other small machines.
    http://www.cnczone.com/forums/chinese_machines/128856-my_j-cut_nightmare_machine_one.html#post944750
    Registered kanton's Avatar
    Jun 2003
    g29cc,
    What information can you save to your computer with the scanner freeware? For example, can you save enough information to draw up the outline of the scanned item?
    Thanks.
    Mar 2008
    You can't save anything at all. The only thing you could do is to write down your information and make a sketch and then draw it up on your cam program.
    Only the full legal version can export and save anything at all.
  1. Tormach Scan Program and Microscope
    By g29cc in forum Tormach Personal CNC Mill
    Last Post: 11-01-2010, 11:45 PM
  2. digitizing vs scanning
    By xyzpro in forum Want To Buy...Need help!
    Last Post: 10-04-2009, 11:43 PM
  3. Spindle mounted microscope for fine alignment?
    By pmurdock in forum General Metalwork Discussion
    Last Post: 05-08-2008, 04:50 AM
  4. Is this the way 3d scanning will go ?
    By greybeard in forum Digitizing and Laser Digitizing
    Last Post: 02-15-2007, 12:52 PM
  5. microscope project
    By haku in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2007, 08:01 AM
