Results 1 to 3 of 3
Thread: Actual RPM
    Mar 2008
    Actual RPM
    Well I bought a photo tach this weekend and just checked a few of my machines.
    NM200 series 1
    1000 rpm on Mach3 was 1029 rpm on tach , 1049 on the VFD behind the machine
    2000 rpm on Mach3 was 2036 rpm on Tach, 2040 on VFD
    3000 rpm on Mach 3 was 3019 rpm on tach, 3035 on VFD
    4000 rpm on Mach 3 was 4029 on tach , 4049 on VFD
    So it seems that I got mine dialed pretty close to what it actually is on the vfd/mach3.
    Just thought I would add that incase anyone else is curious.
    http://www.cnczone.com/forums/chinese_machines/128856-my_j-cut_nightmare_machine_one.html#post944750
    Registered doorknob's Avatar
    Jan 2010
    I am curious about the photo tach - which model and mfg. tach did you get, and did you put a reflective tape onto the spindle or on a tool or somewhere else? How repeatable is the reading?
    Mar 2008
    It was made by Cen Tech. I don't have the box in front of me for model #. But it was from Harbor Freight.
    The rpm varies by a few rpm. Say +/- 5 rpm maybe. Way more accurate then you need really for a machine like this. I took a couple readings and some of them where the same each time. So I believe it was quite accurate for how much it cost and what it was measuring.
  1. Actual Position
    By cncwapner in forum CamSoft Products
    Last Post: 09-21-2009, 11:02 AM
  2. Anybody with actual experience of Practical CNC
    By vid1900 in forum Commercial CNC Wood Routers
    Last Post: 08-24-2007, 11:57 PM
  3. Taig actual travel
    By TMaster in forum Taig Mills & Lathes
    Last Post: 04-06-2006, 07:56 PM
  4. Sheetcam toolpath different than actual
    By KSky in forum SheetCam
    Last Post: 09-13-2005, 12:47 PM
  5. 3 servo motors - What are the actual specs?
    By Bloy2004 in forum Servo Motors and Drives
    Last Post: 06-10-2004, 02:36 PM
