Results 1 to 3 of 3
Thread: Draw Bar
    Mar 2008
    Draw Bar
    I had to make a new draw bar yesterday. I machined a new one from a longer Bridgeport style with a heavier nut end and more thread engagement.
    I bought a 20 1/2 " long Bridgeport bar, cut it down to 12 3/4" , drilled and reamed a hole in the nut end for just shy of 1" depth. Then tig welded the nut to the shaft.
    I had to enlarge the hole in the top cover to fit it through. But its way better now. I feel more comfortable with having more thread engagement then I did prior.
    How many threads of engagement do you guys have with your NM 200 Drawbar ?
    http://www.cnczone.com/forums/chinese_machines/128856-my_j-cut_nightmare_machine_one.html#post944750
    Dec 2009
    I think I have 4-5 threads in collets, after turning down the top collar. No issues to date.
    Did you switch to 3/4 nut from 12mm?
    Mar 2008
    Yes I did go to a 3/4 setup instead of the smaller 12mm.
    Works awesome. Now I have atleast 9-10 threads engaged.
  1. Need Help!- How to draw this?
    By SPEEDRE in forum Solidworks
    Last Post: 06-15-2009, 10:10 PM
  2. Need Help!- ?s on How to draw a Hex.
    By Stampede in forum BobCad-Cam
    Last Post: 02-03-2009, 09:26 PM
  3. Need Help!- okk-mha-400 draw bar
    By Ethan H in forum OKK
    Last Post: 10-07-2008, 09:39 PM
  4. Draw This...I dare you! (or help me)
    By robinsoncr in forum Rhino 3D
    Last Post: 09-17-2006, 09:38 AM
  5. MT's with a draw bar
    By lsfoils in forum General Metal Working Machines
    Last Post: 09-26-2003, 01:56 AM
