What,to do when you don't have a lathe and a vertical lathe won't do.
Results 1 to 2 of 2
Thread: What,to do when you don't have a lathe and a vertical lathe won't do.
    Member AUSTINMACHINING's Avatar
    Mar 2011
    Default What,to do when you don't have a lathe and a vertical lathe won't do.
    I finally found an application for the rotating head on the pro. I had to turn down some 1.25" diameter 304SS tubing 10" long. Needed to remove .007" off the diameter. It wasn't pretty, but served the purpose. LOL.What,to do when you don't have a lathe and a vertical lathe won't do.-2017-02-18-08-51-42-jpg
    Member Novakon's Avatar
    Aug 2008
    Default Re: What,to do when you don't have a lathe and a vertical lathe won't do.
    Your the first that I have ever seen use this feature!
