I had the same issue. Contact John at Novakon. There was a change in the boards and there's a wiring harness adapter that is needed.
I was going to replace my Breakout board but noticed that the new one is missing a connector "spindle enable". The old board I have is a 5.1. Any one have a wiring diagram or can say where these pins are relocated to?
- G0704 stock spindle control board to mach 3 via C32 board.
- Need Help!- Replacing BMU board in AMADA PEGA 357 (Instaling TULIP Fanram Board)
- Need Help!- Home switch for CNC 3020T- with a Spindle Control Board, JP-382A and JP-1482 Board
- Need Help!- Problem connecting spindle inverter to brakeout board C11G
- Need Help c2 sieg mini lathe old circuit board to new board conversion
Made By Viklund
Don't have to be too bright to be me :)
bluehandsvideo on youtube
I was out of town for the weekend. I'll try to get one up in the morning.
Well the machine is up and running again. Thank you john and Mike for fast replies.
I have left the machine on for 1.5 day and not one estop! Before it would estop on me several times per hour.
Made By Viklund
Awesome news! Glad you got it going!
You're more than welcome
