Results 1 to 3 of 3
Thread: Error message from Siemens 840 d/Hitrol
    Jan 2010
    Danmark
    Problems with Hyundai New HIT 8
    Error message from Siemens 840 d/Hyundai Hitrol.
    Is there anyone which do know alarm code # 2001 PLC has not started up.
    And #120201 communication faliet.
    Is it serious difficulties and if, is it expensively to get repaired ?
    Best regards.
    Ole Emdal.
    Registered CNCRim's Avatar
    Feb 2006
    You PLC need to be replace, somehow it seem the PLC fry after certain hours. you can buy and replace it yourself, quite simple.
    Nov 2010
    england
    If all the keys are flashing the PLC hasn't booted, have a look at the NCU card and look at the 2 rows of led's. Also, the display should show a number "6".
    on the NCU card, both top leds should be green above the "6".
    if any red leds are on then you will need to delete the plc and reload the plc archive from the "series start up".
    you will need a siemens engineer to do this and he will need 2 or 3 hours to reset the ncu card and reload the plc.
  1. Problem- error message
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 08-13-2011, 06:39 AM
  2. Need Help!- Error message CR1 etc.
    By NPI in forum Bridgeport and Hardinge Mills
    Last Post: 09-24-2010, 10:34 PM
  3. Need Help!- VMC 3016 Error Message
    By ScopeMachinist in forum Bridgeport and Hardinge Mills
    Last Post: 10-06-2009, 06:25 PM
  4. Error Message
    By Mastercam User in forum Mastercam
    Last Post: 05-10-2008, 11:31 AM
  5. G83 error message
    By HBFixedGear in forum Fadal
    Last Post: 01-30-2007, 10:42 AM
