Prøv å ta kontakt med Plum Machinen i Tyskland. Ser jo ut som en hendig maskin!
Hei
Har en Odessa SMO 32 fres med Heidenhain tcn 355 styring fra 1991.
Får ikke lenger startet opp maskinen (feilkode 47,88 og 46) under oppstarts sekvens
Er det noen her inne med erfaing på disse maskinene?
Mvh
Andreas Djupesland
(Read your similar post at Practical machinist, which I've not got my registration through yet)....
I just purchased the same machine as yours, and am in the process of preparing it for transport (partial dismantling).
Did you ever get to the bottom of your problems?
I've now got the machine manual in front of me, and can tell you the error codes:
88 - Not listed. (I think this is a display test actually, not a fault).
46 - Check the temperature of M4 and 7T1
47 - Hydraulic power unit fails to start
I disconnected the spindle drive motor on mine (removed to lower the machine), and in the process opened the temperature monitoring contact of the system-check circuitry.
When I powered up (to move axis into better positions), the machine gave me 31 - Spindle motor drive thermal protection has operated). It also gave me (30 - ot yet
NO SPINDLE DRIVE READY signal) when I powered with the spindle drive fuses removed).
Having jumpered my temperature monitor circuit (for the disconnected motor), I actually still get code 47. (And did not yet figure out why). I have probably disturbed some wiring in the control cabinet (which is to be disconnected completely from the machine for shipping).
I will try to figure out why my machine has fault code 47, and hopefully I can help you too..
If you don't have a machine manual (and wiring diagram), I can try to get this one scanned at some point. (It is all photocopied hand-typed, hand-drawn etc..)
Kind regards,
Peter Clifton
