Mach3 works with USB as well but you need to get the plugin for your machine from the seller. As far as I remember, you can find some plugins on Mach3 site, but generally that should have been delivered on the CD you got with your machine. Check with the seller or just try to copy the contents of the pirated plugin folder into the legitimate plugin folder.
