Hello,
I just started at a company that does vinyl and composite railing and fencing. They have three machines and all of them have issues. The two newer ones are not cutting straight lines (major chatter) or round holes (oblong or oval). These machines run their own type of cam software that allows you to modify hole locations and end spacing. As far a g-code, it doesn't seem that it is accessible.
My questions are:
1. Does anybody have experience with these machines?
2. If so did you or are you running into the same issues?
3. If you did run into the same issues, what did you do?
4. Is there any type of adjustable backlash compensation? (electrical or mechanical)
And probably more to come as I get more in depth with them.
I want to check backlash on the machine and check to see how level it is sitting. Once I get that information, I will add to this post.
www.machinemotion.com is the link to the company website.
Thank you in advance,
Alex
