Disconnect the motor and see if you get the same alarms. Let me know what you find.
Hi all. I am having a problem with my Daewoo 8S.It has the Fanuc otc control. I am getting a 409 machine alarm and a #12 alarm on the spindle amplifier. I know little about how to fix something like this and was wondering who is the service man in my area or someone who would be interested in fixing it. I am located in Edinburg Va. zip 22824. I am new here so any help or tips would be appreciated.
Thanks,
Ron
We fix it all! Give us a call at 855-437-3497.
I will give it a try and see what happens. Thanks
Any time. Feel free to email me your results. tyler@iesrepairs.net
Tyler, I checked the motor wires and they are way back in the machine and impossible to get to. Can I unhook it at the KM-10 breaker that it keeps tripping inside the control cabinet? Also if the motor is pulling to many amps what amps what should it be pulling? I have a friend that is knowledgeable on electronics.
You should be able to disconnect the motor at the amplifier.
Your amps question depends on the load. The higher load, the more amps. There's not really a set value it should have. If it trips the breaker with no load, there's more than likely a problem with the amplifier.
If you power the machine down, disconnect the power to the amplifier, and the breaker still trips after powering the machine back on then you have other issues. If it doesn't trip the breaker, then there may be a problem the amplifier or motor.
Is it tripping the breaker immediately?
Feel free to give us a call. 855-437-3497. It may be easier to explain everything over the phone. Haha
You'll want to talk to Eric. His extension is 105. He will be gone from 2pm-3pm.
Okay, we unhooked the wires but the machine woud not power up. Hooked them back up and re-powered it. Relay km-10 immediately trips out when pushing spindle run button and machine shuts down. It puts alarm 409 on the screen, 12 on the amplifier, and 04 on the machine alarm. He put his amp meter after KM-10 and never saw the motor draw any amps.
From your description, it sounds like there;s a problem with your amplifier. My suggestion is to send it and your motor in to us for evaluation. It's free so it won't cost anything. We'll take a look at them. Check out our website Industrial Electronic Repair & Servo Motor Repair | International Electronic Solutions or email me at tyler@iesrepairs.net for our shipping info.
