New Product RosettaCNC Motion
Results 1 to 1 of 1
Thread: RosettaCNC Motion
    Jul 2017
    Italy
    Default RosettaCNC Motion
    RosettaCNC Motion is an innovative and complete CNC control system.
    Years of research and development have led to a powerful Ethernet controller that manages up to 4 interpolated axes.
    We have developed a powerful and easy-to-use control software.
    Features
    Continuous 4 axis interpolation
    RosettaCNC can handle up to 4 continuously interpolated axes. Each axis has its own parameterization. Accurate acceleration control is performed during interpolation.
    Look ahead of 1000 points
    RosettaCNC Board implements, like the most advanced CNCs, the Look-ahead function that allows you to increase tool speed while running Gcode with small segments. The depth of the look-ahead implemented is 1000 points.
    Bezier fitting
    When “CONTINUOS” work mode is selected, RosettaCNC Board moves the axes to try to keep the tool at constant speed. When you are in the presence of an edge, it is rounded up with a quadratic Bezier type trajectory. The amount of rounding can be set with a dedicated parameter.
    Ethernet connection
    Fast, robust, isolated. These are the characteristics of the 100Mbit Ethernet connection used for connection to the PC.
    On-board control and connection from office
    Thanks to the ethernet port that manages two simultaneous connections, it is possible to control CNC machine through the RosettaCNC software and at the same time another communication acts as supervising or sending work file.
    Remote Supervision
    Thanks to a peer-to-peer communication infrastructure, it is possible to control workmanship comfortably from home or to be informed about certain events such as alarm, tool change, end processing, etc. (in development)
    Ready for Industry 4.0
    Dual etherneth communication channel, sending work from office PCs, SDK to develop interfacing with management software, etc. All of this makes RosettaCNC the right solution for who want to integrate the product into a scenario that meets the Industry 4.0 needs.
    Accurate acceleration check in any condition
    Each movement is verified by the trajectory generator to ensure the right acceleration value. This is useful for avoiding mechanical stresses but also to avoid losing any steps when you run STEPPER motors. All movements and conditions are verified: JOG, HOMING, PAUSE, REPAIR PROCESSING, FAST SHIFT OVERIDE, STOP PROCESSING, ecc...
    Automatic software update
    The new software is distributed either by publishing a new installation package or by using an automatic update system. Distributed software is always stable. Automatic updating ensures that new features are deployed quickly and practically.
    STEP output up to 300KHz for each axis
    STEP / DIR command outputs are generated by a powerful FPGA that allows to reach 300KHz operating frequencies (with 50% duty cycle stable), making it possible to use both stepper drives and servo drive.
    A development team for a innovative product
    The development team is always at work to develop new features and make RosettaCNC a complete product
    Feed control using digital MPG
    The feed is controllable by an external MPG. Its digital signal allows accurate control of the value avoiding variations by humidity, wear, temperature, offset of electrical circuitry, etc …
    Customization
    For special needs software customizations are an option.
    PC SOFTWARE
    Meanwhile RosettaCNC Board executes standalone all interpolated movements reading data informations from internal big not-volatile buffer, the RosettaCNC software is used to monitor, edit, compile and configure any aspect of your machine in a simple graphical way.
    Lock the home site http://rosettacnc.com/en/ or visit the forum http://forum.rosettacnc.com/
    Attached Thumbnails Attached Thumbnails RosettaCNC Motion-screenshot-14-jpg
RosettaCNC Motion
RosettaCNC Motion
