Ready Motion Control Ported to GRBL 0.9j
Results 1 to 1 of 1
Thread: Ready Motion Control Ported to GRBL 0.9j
    May 2017
    Default Ready Motion Control Ported to GRBL 0.9j
    I would have posted this in my old thread but its closed so here we go. We ported the Ready Motion Boards over to GRBL 0.9j using a MEGA 2560. The system still has
    1. 8 Axis
    2. 32 Outputs
    3. Isolated Digital Limit Switches
    4. Use of mechanical buttons (if using our interface)
    5. Easy PWM access
    6. Clean wire design
    If your looking for a clean look and more power from your GRBL CNC look no further this GRBL shield is for you! Goto www.readymotioncontrol.com for more info and pics!
    Here is a image of the Ready Motion Installed Running GRBL 0.9j mod.
    We have 6 AXIS hooked up and 1 output of 8 to control a 2 hp motor controller. Pictured also is a fuse box and 24 volt and 5 volt power supplies below.
    Interface Features:
    • Axis locations
    • Multiple users can log in to see whats running
    • Jog Buttons for all axis with feed rates and distance control
    • Program editor with syntax highlighting
    • 6 programmable macros that save with your program
    • Real time program status for error debugging and status
    • Real time line number status
    • Pause and Resume
    • Reset Button
    • Enable mechanical buttons to control everything on the user interface
    • Offline G- Code visualizer
    • Advanced mode to easily change system settings like
    • Stepper Motor Resolution
    • Stepper Drives Pule Control
    • Max Feed Rate
    • Max Travel
    • Stepper Motor Acceleration
    • Invert Step Signal
    • Invert Direction Signal
    • Stepper Idle Delay
    • Enable Soft Limits
    • Enable Hard Limits
    • Invert Limit Signal
    • Enable Homing
    • Switch Homing Direction
    • Homing Feed Rate
    • Homing Limit Debounce
    • Homing Pull Off Distance
    • Output Toggle Switches
    • Default G Code Coolant, Spindle, Laser Buttons
    IMAGES
    Attached Thumbnails Attached Thumbnails Ready Motion Control Ported to GRBL 0.9j-advscreen-jpg   Ready Motion Control Ported to GRBL 0.9j-main-screen-jpg   Ready Motion Control Ported to GRBL 0.9j-img_20170803_072957124-jpg
