Cheewoo Engineering is releasing 3D pipe CNC profile cutting CAM software program Cheewoo Pipe CAM.
Cheewoo Pipe CAM can perform following features.
- Generating NC code file for 2~4 Axis CNC pipe coaster machine / pipe profile cutting machine with easy and conveniently.
- Supporting both rotation and link head mechanism kinematics.
- Able to generate complex 3D pipe cutting path trajectories by using combinations of simple geometrical parameter inputs.
- Saving current job into project file and also can add already saved project files into current job easily.
- Various pre-defined perimeter cut, hole cut and composite cut models are supported as 3D templates.
- Lead-in/Lead-out setting and kerf width/taper setting are available for accurate 3D cutting.
- Including RS232C serial comunication capability for sending NC code to legacy CNC machines.
- Requires Windows 2000 or above, RAM512 MB,10MB HDD or above.
Please check more detail informations to visit Cheewoo Engineering website Cheewoo Engineering .
You can download trial version of this software from this link : Cheewoo Engineering - Download Cheewoo Nest 1D
