OnCreate3D First Full Cloud CAM app add feature to share projects and much more ...
OnCreate3D, First Full Cloud CAM app, makes life easy for Design Engineers & Machinists, by allowing to share their project(s) with other users (operators, decision makers etc.) Machinist seating at his remote office can create NC Files for CNC Machines in his production facility. He can simply share his project with operator who can download NC File and run the machine. The machine that Machinist programmed for is busy...? No problem, operator can configure POST to output new NC File for different CNC Machine. Create toolpath operations only once and use it for different locations, different machines multiple times. Machinist doesn't want operator to change his toolpath operations? Simply give READ permission. Machinist wants to allow operator to edit toolpath parameters to suit machining conditions? Give him WRITE permission.
OnCreate3D has also introduced toolpath simulation to visually check for correctness of toolpaths before downloading NC Files. Users can customize POST parameters as well to generate correct sequence of commands in NC File.
Check out latest deployment at www.OnCreate3D.com. Sign-up, it is FREE until June end 2017.
