YES Another Fadal Retrofit!!!-But Made in Germany...
ImpactiQ is what it is called.
It is a true plug and play retrofit that is installed on your existing Fadal mill in 2-4 hours. New HMI with 17 inch multi point high definition touch screen bolts right into existing Fadal control box. Custom made wiring harness runs from HMI directly to control cabinet, where a brand new industrial PC system (made in Germany), easily bolts into spot where old school control boards were.
It comes with a 3 year part/ labor warranty, and is inexpensive and can be financed for less than $400 a month. New control has near unlimited memory (20 gigs)...you will no longer have to drip feed long programs, and with its new processing ability you will no longer have a machine starving for data. Better part finish, greater tool life, less wear and tear on the machine, and more money in your pocket!
The new control will give you full high def 3D part display on the screen, a fully customizable display, USB interface, internet connection (check emails while running machine,ect.), massive amounts of memory, and user friendliness. Say you have an issue with the control...well no problem, because it is hooked to the internet a tech can remotely diagnose most problems without having to even step into your door. Its complimentary of course, and no trip charge like the others.
Best part...all your programmers and operators who work with Fadal, they will require no training. All of our installs are amazed at how effortless the transition is. All the buttons on the new keyboard are the exact same. It reads your current Fadal programs. Nothing changes for you except you bring more money into your pocket and your machines into this century!
The company who builds the control is called Power Automation out of Germany. Their controls have a near zero failure rate. Hence the 3 year warranty. Here is a link to their website.
They even have some articles on this control on their site. https://www.powerautomation.de/home/
If you want a quote all you have to do is fill out a form specific to your Fadal machine. Email me and I will get to you. raormrod@yahoo.com
