uv laser marking machine is a kind of cold laser source which good for use engraving on the diamon,jewelry ,it is fine for protect the raw material when process.for more detials please link to www.hanzlaser.com
Main Functions:
1、 With stable laser output, high precision and power can adjust continuous.
2、 Used for mark any picture, words, LOGO, bar-code, BMP, two-dimension code etc. And it can achieve jump change code number function too.
3、 Support WIN XP operation interface, support PLT PCX DXF BMP format, can use the SHX TTF font library.
4、 Machine with good performance, can works for 24 hours continuous.
5、 With the import accessories, can be used widely for special process.
always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: zgzg1125@hotmail.com Skype:lisaseekcn
