6 Axis USB Mach3 CNC Motion Control Card Breakout Board 200KHz Windows 7
- Support all versions of Mach3.
- Only for Windows operating system (not including Mac OS).
- USB jack does not need to install the driver, plug and play under all versions of Windows.
- Full support USB hot-swappable, USB connection status monitoring at any time. Under Mach3 working state, USB cable unplugs and then plugs in, but also the normal connection.
- Supports 6-axis linkage.
- Maximum step-pulse frequency is 200 KHz, can connect servo driver/stepper driver.
- The indicator light indicates various working status, such as USB connection, Mach3 connection and so on.
- 16 input IO.
- Speed testing function, the spindle actual speed displays on the Mach3 interface in real time.
- Onboard isolated power supply, not need external power supply.
- All IO port fully isolated, strong anti-interference, stable performance
- Support XHC series of wireless electronic MPG, such as WHB04 MPG.
- Support spindle speed PWM output; support spindle pulse and direction output; support spindle speed output from 0 to 10V analog voltage.
contact me: proxsmart@gmail.com
CNC Control System Solution[email: ucontro@hotmail.com]
https://www.aliexpress.com/store/1100407278
