Hihg precision Adopt SANYO servo motor . The combintion of imported ball-screw and linear- guiding make it has high percision.
High reliability All the core parts and components are adopt international famous brands . such as the laser is UK GSI, the motor is JAPAN SANYO and the water-cooling system from Shenzhen SUNRISE Industrial CO.,LTD.Ultra low operation cost and simplicity of operation(the operation cost less than 15 RMB/ hour).
specification
Laser type
Sealed CO2 laser tube
Laser power
200w(GSI)
cutting area
1300*1300mm
Resetting positioning accuracy
±0.05mm
Power supply
220V±10%/40A
Operating temperature
0 - 45°C
Operating humidity
5- 95%
Minimum shaping character
English 1 x 1mm
Graphic format supported
BMP,PLT, DST, DXF, and AI
Cutting thickness
30mm(max)
Cutting speed
20m/min(max)
Net Weight
1500kg
Applicable materials
Die-cutting plate,wood, organic glass,plastic, garments, paper, leather, rubber, and other nonmetal materials.
Applicable industries
advertisement, arts and crafts, shoes, toys, garments, model , building upholster, computerized embroidery and clipping, packaging and paper industry.
