GWK1325 CNC metal laser cutting machine
Compared with other equipments, the advantages are as follows: 1、High precision: applicable for cutting on precision parts, calligraphy and painting. 2、Fast speed: its quicker 100 times more than line cutting. 3、Small heat-affected zone, not easy to metamorphose, cutting edge is smooth and beautiful, no need to do after-process. 4、High performance: It’s price is only 1/3 of similar performance CO2 laser cutting machines and 2/5 of CNC punch machines. 5、Low using cost: its using cost is only 1/8 to 1/10 of similar performance CO2 laser cutting machines about RMB18 for each hour, however the using cost of the CO2 laser cutting machines is about RMB150-180 each hour. 6、Low maintenance cost: only 1/10 to 1/15 of similar CO2 laser cutting machines and 1/3 to 1/4 of similar performance cnc punch machines. This model adopts DSP controlling system, auto height adjust system imported from USA, linear guide and ball screw imported from Taiwan, servo motor imported from Japan, USA lens and mirrors, special double ball screw and double servo transmitting system on Y axis, strong structure for whole machine. All these characters made this machine to get the leading level for both function and stability.
Specification:
Model number: GWK1325
working area: 2,500mm×1,300mm
machine size: 3,645×2,015×1,300mm
Max. cutting thickness: 6mm(carbon steel)
Max. output power: 620W
laser wavelength: 1064nm
Pulse Frequency: 1-300HZ
Minimum line width: 0.15mm
X,Y,Z axis Resetting position accuracy: ≤±0.04mm
Cooling mode: 7P water cooling system
Max. cutting speed: 35mm/s
Voltage: 380V/50HZ/100A
Whole machine Weight: 3000kg
Appliable industries:
Widely used in the line of advertising board, Sheetmetal structure, high and low Voltage elictric cupboard industry, spare parts of the textile machines, hardware, metal handicraft article, kitchen wares, cars, machines, elevators, spare parts of the elictric devices, spring pieces, spare parts of the subway and so on.
Appliable material:
Stainless steel, carbon steel, alloy steel, spring steel, Aluminum alloy, copper plate, Aluminum plate, gold, silver, Titanium, other metal plates and metal pipes.
