small co2 laser engraving machine
Results 1 to 2 of 2
Thread: small co2 laser engraving machine
    Registered hanzlaser's Avatar
    Apr 2011
    china
    Default small co2 laser engraving machine
    laser power: 70-80w
    processing area:300x300mm
    Minimum forming words: Chinese characters 2 x 2mm, letters 1 x 1mm
    carving speed : 0-64000(mm/min)
    cutting speed: 0-36000(mm/min)
    resolution ratio: less than 4000 dpi
    power supply: AC220V±10%
    positioning accuracy: less than 0.01m
    Hang line number: 60 lines
    total power: less than 1250W
    operating temperature: 0~45℃
    Machine weight:50kg
    Operating humidity: 5~95%(free of condensed water) Graphic file format: BMP、JPGE、PLT、CDR、DWG、DXF、DST
    Attached Thumbnails Attached Thumbnails small co2 laser engraving machine-co2-jpg
    always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: zgzg1125@hotmail.com Skype:lisaseekcn
    Registered RoseChina's Avatar
    Dec 2011
    China
    Co2 laser machine
    It is widely used on non-metal materials. Such as rubber, acrylic, plexiglass, bowlers, crystal, wood, plastic etc.
