If you want relief from mold then make sure that your home must be well ventilated. It makes air to pass from one part of room to another, this keeps air dry and hence no mold will form.
mold damage repair great neck
Product Highlights
Laser control system: HZW-W200 laser welder is under the control of double closed loop by inside improved industrial controlling micro-computer so the stability and the running ability surpass products that controlled by monolithic integrated circuit. The laser controlling system can control the power source profile precisely pre-set optimized.
Gas protecting system: synchronous argon protecting system controlled by micro-computer act better, it make the welding connection even firmer and artistic. Being controlled to keep synchronous transmission with laser can save the argon at the highest level.
Observing system: It's equipped with special-purpose microscope observing system with cross cursor. It has high speed electron flitting device to protect the operator's eyes from being hurt.
________________________________________
Parameters Name Parameters
Max. laser average power 200W
Laser peak value power 5KW
Laser wave length 1064nm
Max.single pulse energy 75J
Pulse width 0.3-20ms
Welding frequency 0.5-100HZ
Cooling Mode Water-cooling
Welding Spot size 0.2-2mm
Welding depth 0.1-3.5mm
Laser welding wire 0.2-0.8mm
Positioning Microscope(Optional CCD)
Max. welding position 500mm x 1000mm
Laser working area 200mm x 200mm x 300mm
Laser control mode Electromotion
Power consumpted ≤11KW
Electrical demand 220V±10% / 50Hz / 30A
Usage environment Clean,no shaking,Temperature 13 ℃ -28 ℃, humidity 5% -75%
always provide the good resolution of laser cutting,laser marking,laser welding equipment for you. www.hanzlaser.com MSN: zgzg1125@hotmail.com Skype:lisaseekcn
