Hi everyone, enjoy our day and life. It is nice and beautiful spring now in China. May day is coming. People usually go to some tourist places for intresting sinery or for family party. Do you have plan to foreign country, such as Iraq, China, Franch and so on. World Expo is going to begin, will you come to Shanghai?
Jiuzhai Valley in Sichuan Province and Yellow Fruit Tree in Guizhou Province is very famous tourist spot and suitable to visit this season.
At this time the weather got wamer and the water of the lake was still like a mirror, and with the result that it had a kind of special, mysterious flavor.
Near the Yellow Fruit Tree Waterfall are now 18 falls at nine different levels, each with a drop of more than ten metres. And many are the waterpools formed by the cascading waters.
more than ten kinds of grider are on sale for ur choose HG-01A HG-01B HG-01C HG-02A HG-03A HG-03B HG-03C HG-03D HG-04A HG-04B HG-05A HG-05C HG-07 HG-09 HG-10
There wil be sure to be one modal suitable and useful for u now or in the near future.
In June of the year 2010, a new company will be established by Taiwan How-Mau Machinery Co.,Ltd in New York. We would like to look for staff and agent who are interested in cnc machine. Welcome to engage in talks with our Manager, Mr. Cheng, Jimmy. work@diylife.com.tw
Skype:dearatron msn:a0937409596@yahoo.com.tw
Our mini CNC lathe and mill is very popular for their best quality and perforamce, especially competitive price. First , it is manufacture that Taiwan How-Mau Machinery Co.,Ltd is. We have our own professional researching and developing team of which four engineers with more than 20 years experience. Second, our mini cnc machines are directly sold into market from factory. Customers will save lots of unnecessary fees. Best after-service could be enjoyed from our agent in first time. Third, end-users are able to get our machine from stock in USA or in China after payment ASAP.
Installing probe system in cnc machine, it is able to automatically finish size detection, tool correction, establishing coordinates, etc. Work piece is not necessary to be taken off, just holden on machine to be tested precision and corrected size error by probe till work piece is qualified.
If u look for multiple function vice, there is easy to find there.
HMTW13(QB) SEYIES M,ACHINE VICE
It is more suitable for lathe, drill machine and planer, could rotate 360 degree on the same level surface, open width is large, clamping range is wide.
HMTW41 SEYIES MACHINE VICE
It is decline vice, suitable for cannot machining 60 degrees face and back, rotate 360 degrees on the same level surface.
Type MFZ-4N electronic cutter calibrator special for CNC lathe
1.This calibrator works on the principle of electric conductivity. It can be used to calibrate in the direction of the X-axis and Z-axis of the machine coordinate. With MFZ-4N calibrator, it is not necessary turn the spindle of the lathe or to make a trial cutting for measuring, so the calibrating operation is easy, fast and the calibrating accuracy is high. It is beneficial not only to increase the productive efficiency, but to guarantee the quality of the products.
2.The calibrating operation and principle A. the preparation for the calibrating. Fist of all, change the state of the lathe to the manual one, then install the calibrator on the CNC lathe. B. The calibrating in the direction of X-axis. Move the turning cutter on the lathe slowly by hand, make the tip of the cutter move toward X-axis. When the tip of the cutter touches the sylinder surface of the calibrator standard ring, the calibrator sends out the light and sound signal and undertake the operation of the “accurate touching” and then set the position of the cutter tip in the machine coordinate according to the values of the machine coordinates given by the CRT of the machine CNC. C. The calibrating in the direction of the Z-axis . Move the turning cutter on the lathe slowly by hand, make the tip of the cutter move toward Z-axis, when the tip of the cutter touches the surface of the calibrator standard ring, then the calibrator sends out the light and sound signals, and set the exact position of the cutter tip in the machine coordinates according to the values of the machine coordinates given by the CRT of the machine CNC.
3.The function and characteristic. The internal power supply of the calibrator is composed of the chargeable batteries(Ni-MH, 300 Ma/h), it can be charged on the other power supply (100-240 V/AC) by the special charger provided. The working state is indicated by six red lights and a buzzer sound together, so the operation is very easy and fast. The standard ring of the calibrator can swing to any direction, so it is very safe to operation.
4.The notes of the technical terms: A. The principle of the electric conductivity. The cutter and the machine are two parts of the internal circuit of the calibrator, when the turning cutter and the calibrator are installed on the CNC lathe. The circuit will ne connected when the cutter tip touches the surface of the calibrator ring, so the calibrator sends out the sound and signals at the same time. The accurate touching: It is the sate that the edge of the cutter has touched the surface of the standard ring and the ring does not move at all or even the ring moves, but the distance between the ring and its original position can be neglected.
5.The calibrating accuracy: The real accuracy on the CNC lathe with MFZ-4N mainly depends on the locating accuracy of CNC lathe, the centering accuracy of the clamping plate and the accuracy of the calibrator. The accuracy of the calibrator: The tolerance of the returning location of the standard ring is smaller than 0.002(MM) after swing to any direction, the other accurate values are the same as those of the MFZ-3.
Have u thought to reduce most unnecessary cost from manufacture to extend ur market?Have u ever thought to buy the best mini cnc machine with the lowest price some times? Have u ever heard or found this manufacture with best price and after service in the world mini cnc machine market? All of these could come true easily with us, Taiwan How-Mau Machinery Co.,Ltd. It is not dream now.
hm-135 cnc bench series mill
2999us$ FOB Qingdao the lowest price in the market
Including bare machine, stand and controller
More information, pls download and look at attachment.
We are factory specializing in the manufacture and export of mini CNC machine for more than six years. We have profuse designs with series quality grade, and expressly, our price is very competitive because we are manufactory, we are the source.
EVERYBODY BE CAREFULLY THIS COMPANY.
the howmau owner have been move to US,and drop a lot of debt in china.
i post a lot of story,but now delect by cnczone,it is should be konw for everybody ,carefully do business with them.
they cheat a lot of factory,so,nobody make supply to them now.
even though them old customer novakon,also drop them....
