- 1000W high speed IPG fiber laser cutting machine - No Longer Available
Why choose EETO-FLS3015-1000W (IPG)?
?High Performance Yaskawa Motors fixed to a gantry and cross slide structure
?Superior edge quality plus high quality cutting head
?High precision driven box using World Leader-Top Quality Rack&Pinion Drive Technologies and Gearbox
?World famous IPG laser generator
?Direct laser control with PWM (Pulse width Modulation?
?5.0?and 7.5?Focus length high pressure lenses with Digital Focus Adjustment
?Automatic Gas Assist System
?Advanced Cutting Head anti-collision device
?Pallet shuttle system with two 3000mm by 1500mm working pallets
?Windows? Driven Software with materials Parameters Database
?Fully interlocked Safety Enclosure on cutting table
?Advanced Metal Cutting Post Processor software
Advantages
?Adopt State-Of-Art Crossbeam and Light Weight Material
?Integral welding technology ensure longer constant stability and longer life
?The whole frame is finished through Temper Treatment as well as Vibration Test
?Dual-Driven Gantry Structure, stable and Excellent motion performance
?High Speed & High Acceleration
?Adopt the Best Parts from China and overseas
? Standard Configurations of EETO-FLS3015
Major Configurations Content Brand
Laser Generator Optional IPG
Laser Cutting Head Manual Focus
Auto Focus (Optional) Raytools, Switzerland
Height Controller Capacitive transducer BOCHU, China
CNC Controller Cypcut
Professional Laser Cutting Software Fscut
Speed Reducer SHIMPO SHIMPO, Japan
Rack and Pinion YYC YYC, Taiwan
Linear Guide TBI TBI, Taiwan
Proportional Valve SMC SMC,Taiwan
X/Y Drag Chain Domestic Cangzhou, China
Shield Cover Domestic Cangzhou, China
Industrial Water Chiller Domestic Tongfei, China
Industrial PC and LCD Screen Domestic Shenlanyu, China
Voltage Stabilizer Domestic FATO,China
? Technical Data of EETO-FLS3015 Series Fiber Laser Cutting Machine
Total weight Tons 6
Total Electrical Power Consumption Kw 11
Laser Type Famous fiber generator
Laser Wavelength nm 1070
Resonator Power w 500 700 1000 2000
Fiber Core diameter um 100
Maximum Cutting
Thickness Mild steel mm 6 8 10 16
Stainless steel mm 3 4 6 8
Aluminum mm 1.5 2 3 5
Net Cutting Diameter mm 1500*3000
X.Y Axis Drive system Rack and Pinion
Z Axis Drive System Ball screw
Z Axis stroke mm 130/230
Maximum Simulation X,Y Axis Speed(Idle speed) M/min 80
Maximum Acceleration X,Y Axis Speed G 0.8G
Position Accuracy mm/M 0.03
Repeatablity Accuracy mm/M 0.05
Cooling Style water
Bearing Weight kg 1000
Assistant Gas Oxygen,Nitrogen, Compressor Air
Dimension MM 4300*3200*1700mm
Continuous Working Time Hrs 24
Material Thickness(mm) Cutting Speed(mm/s) Recommend Gas
Carbon Steel 1 300 Air
2 130 Oxygen
3 55 Oxygen
4 36 Oxygen
5 25 Oxygen
6 21 Oxygen
8 16 Oxygen
10 12 Oxygen
Stainless Steel 1 350 Nitrogen
2 150 Nitrogen
3 45 Nitrogen
4 25 Nitrogen
5 16 Nitrogen
6 10 Nitrogen
List Date: 9/20/2017
For more info, click here to view the original listing: 1000W high speed IPG fiber laser cutting machine
This item is no longer available.
Re: 1000W high speed IPG fiber laser cutting machine - No Longer Available
need the operation manual for Tongfei Water Chiller TFLW-1000WDR-03Z-1225
can you share
thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
