Grizzly G0704 CNC Conversion with enclosure
G0704 CNC Converted.
Mill Specs/ Included:
# X/Y/Z "Double Nut" Ball Screws
#High Torque Stepper Motors
# 3 Axis Controller
# Mach 3 Software
#.0001 Accuracy
# X/Y/Z Limit/Homing Switches
# Dovetail column
# Safety shut off switch
# DRO on spindle
# Fine feed head control
# 2 Speed gear box
# Clear guard on spindle
# Rubber chip guards on ways
# Zero setting dials
# Dials read inches
# Tapered gibs throughout
# Forward/Reverse switch
# Stand with chip tray and cabinet
# Motor 1 HP, 110V, 3.2A, single-phase
# Spindle taper R-8
# Spindle travel 2"
# T-slots 3 @ 2-1/2" centers, 3/8" studs
# Head travel 11"
# Head tilt 90?; L/R
# Max. distance spindle to table 13"
# Swing 14-3/4"
# Table travel (longitudinal) 18-7/8"
# Table travel (cross) 6-7/8"
# Table size 7-1/8" x 26-5/8"
# Range of speeds Variable, 50-2250 RPM (Variable Spindle Control Installed)
# Table Capacity 125-150 lbs.
# LED Spindle Work Light
Swapped to C10 board for Linux CNC. Needs limit switches wired, and C41 board for spindle control.
Or, swap back for Mach.
List Date: 6/12/2017
For more info, click here to view the original listing: Grizzly G0704 CNC Conversion with enclosure
This item is no longer available.
