Cincinnati Arrow 1000
Looking to sell MY97 Cincinnati Arrow 1000 that I'm retiring as one of the amplifiers may be faulty and selling as is, or may consider parting out pending part/s.
Equipped with:
Acramatic 2100 PC Based CNC Control with coloured CRT monitor
Fanuc 0 Program Translation
Floppy Disk Drive
RS-232 Port
21-Station Automatic Tool Changer
Maximum program storage
4th Axis Prewire inc. Axis Drive
MC Extended Cycles
Tool Cycle Timer & Counter
Migrating Tools
Full Coolant Enclosure
Chip Conveyor
Through Spindle Coolant Delivery System
Specifications:
X Travel (Longitudinal)................................ 1020mm (40.16")
Y Travel (Cross)........................................... . 510mm (20.08")
Z Travel (Vertical)........................................ . 560mm (22.05") / 687mm (27.05")
Table Working Surface................................ 1120mm x 510mm (44" x 20")
Table Workload Capacity............................ 700kg (1544 LBS)
Spindle Horsepower.................................... 15 HP
Spindle Speeds............................................ . 60-8000 RPM
Spindle Taper............................................. ... CAT 40
No. of Speeds............................................ .... 1rpm Increment, infinite variable
Feed Rates, X, Y & Z...................................... 2.5mm to 12,000mm/min ( 0.1 to 472 In/min)
Rapid Traverse, X, Y & Z............................... 20m/min (787 In/min)
Tool Storage Capacity.................................. 21
Approximate Dimensions (floor space)..... 3500mm x 2550mm (138" x 101")
Approximate Height..................................... 2750mm (109")
Approximate Weight.................................... 4545kg (10,020 LBS)
Serial Number............................................ ... 7049A0ARM0144
Price Negotiatble
List Date: 4/3/2017
For more info, click here to view the original listing: Cincinnati Arrow 1000
This item is no longer available.
