BRAND NEW PANASONIC C02 LASER OSCILLATOR YB-LSERIES (POWER 2.5kW)
-DESIGNED TO REDUCE CONTAMINATION PARTICLE TO THE MIRROR BY OPTIMIZATION OF THE MIRROR
AND THE EFFECT OF THE GAS SHIELD
-?CREATE STABLE MODE BY OPTIMIZED DC POWER SUPPLY, ELECTRODES AND GAS FLOW. PROVIDE A HIGH
QUILTY EDGE AND ACCURACY IS ACHIEVED
-? ENGRY SAVING PROFORMANCE STRENGTHENING BY LOW ELECTRIC POWER HIGH VELOCITY? CREATING PURE BEAM MODE APPLIED TO VARIOUS MATERIALS FROM ?SHEET METAL HIGH-SPEED CUTTING? TO ?THICK PLATE CUTTING?
MAXIMUM SHEET THICKNESS: ? ALUMINUM 8MM ? 400MM/MIN.N2? STAINLESS 10MM ? 550MM/MIN.N2 MILDSTEEL 22MM ? 650MM/MIN.O2
RATED OUTPUT & MODEL: 2.5KW \YB-L25C10
SYSTEM: DC DISCHARGE-EXCITATION HIGH-SPEED AXIAL FLOW CO2 LASER
POWER RANGE: 125 ? 2500W
WAVE LENGTH: 10.6 uM
BEAM MODE: TEM00
PULSE FREQ / PULSE DUTY: 1 HZ ? 1KHZ / DUTY 0% - 100% 1KHZ ? 2KHZ / DUTY 20% - 100%
LASER GAS COMPOSITION: HE : N2 : CO2 GAS MIXTURE
LASER GAS CONSUMPTION: 10 Liters/Hour
INPUT VOLTAGE / HERTZ: 400V + 10% - 15% / 50HZ / 60HZ
MAX POWER CONSUMPTION: 26 kW @ 115% CW Power
COOLING WATER FLOW: 100 Liters/Min
RECOOMENDED COOLING CAPACITY: 24.7 kW
WATER TEMPERATURE: 20-25 celsius
MASS: 950 kg
Note: ITEM HAS MINOR RUST SPOTS DUE TO CONDENSATION IN CONTAINER DURING SHIPPING, ITEM SOLD AS IS. Pictures upon request.
List Date: 3/7/2017
For more info, click here to view the original listing: BRAND NEW PANASONIC C02 LASER OSCILLATOR YB-LSERIES (POWER 2.5kW)
On Sale For: $350,000.00
