Where is it located?
Grizzly G0704 CNC Conversion Project - I started... you Finish!
Thinking of taking on the conversion of a Grizzly G0704 mill to a CNC machine but don't want to deal with:
- Waiting for Grizzly to ship you the mill
- Machining the conversion parts
- Disassembling your mill
- Ordering the ball screws
- Machining the saddle for clearance
Well you are in luck! I started the Hoss based conversion and have since found myself at a shop with a larger CNC machine. I don't think I'll ever get around to finish this project, my loss is your gain. Here is what you get:
- Un-assembled G0704 mill with most of the stock parts (I have the lead screws at least, and I think most of the rest.
- The clamp kit and most of the accessories
- The X, Y, Z motor mount adapter plates (all the parts from the Hoss instructions)
- The ball screws prepared for double thrust bearing configuration
- Most of the bearings and shims you will need. $226 in McMaster-Carr parts for the build alone!
I was basically at the stage of the project where I'd need to assemble the mill and install/order all the control electronics and motor stuff.
Local pick up preferred, but I supposed I could ship several packages if you wanted to pay for that.
List Date: 8/22/2016
For more info, click here to view the original listing: Grizzly G0704 CNC Conversion Project - I started... you Finish!
This item is no longer available.
I need to find myself a deal like this. I am getting close to ordering a G0704 but keep hoping something else will pop up for sale.
