K2CNC router machine FOR SALE
K2CNC router machine (KT-2514 version 2010.)
.20mm shafts, BSA brand lead-screws and nuts with 0.100 inch pitch.
5.5" Z axis.
Router Mount for Porter Cable Router Model 892 (will fit most 3.5? diameter routers)
(Router NOT included)
Aluminum Table-Top T-Slotted. (Sectional top. Each is 0.750" thick, 6" wide per
section. Each T-lot is 2" apart, T-slot starts 1" from the edge.)
__________________________________________________ ________________________
Hardware Enclosure for Power supply, Chopper driver, and Breakout Board.
PBX-2 Parallel Port Breakout Board
24Volt 6.5Amp Switching Power Supply
ProboStep Uni-polar Stepper Motor Chopper Driver.
3 - HT23-280-8 Stepper Motors
Printer Cable (DB25-pin) from enclosure to computer - Print card included if 25 pin printer cable hook-up not available on computer.
No software included. (xml file for Mach3 included if needed)
****Prefer Local Houston, Tx Area buyer for pickup arrangements.
Asking price $1400.00 dollars OBO as Listed
$1000.00 dollars OBO for Frame ONLY.
Contact: signcut329@yahoo.com
List Date: 8/3/2015
For more info, click here to view the original listing: K2CNC router machine FOR SALE
This item is no longer available.
- Need Help!- K2CNC 4925 router
- CNC router machine for sale
- Need Help!- K2CNC router help needed
- K2CNC KG5050 router
