Electronic CNC components
4X DG2S16035 drivers
3X SEM servo MT30M4-28 with CUI encoders
1X SEM Servo MT30M4-59 with the standard optical encoder
3X BRKC-180 servo brakes
1X C36 quad relay board
1X C32 BOB Revision 4
1X Ethernet smooth stepper
1X VFD GS2-22P0
1X LR-22P0-1PH 1PH input line reactor
1X LR-22P0 Ouput line reactor
1X 20DRT1W3S EMI input filter
1X MS-15-5 Meanwell 5VDC power supply
1X MS-15-12 12VDC
Bridgeport 130 VDC power supply
Ethernet cables and connectors
3X High watt wire wound resistors
Additional capacitors for the power supply.
soft start circuit
Basically everything you see in the pics including cables for the 3 servos.
I am not including the enclosure, fan, or main breaker
I'll also throw in the computer in the first attachment pic with fully licensed Mach III .
Perfect package for anyone wanting to CNC any machine tools they already have.
This came off a Bridgeport CNC
List Date: 3/26/2015
For more info, click here to view the original listing: Electronic CNC components
This item is no longer available.
