Hello CNCzone.com Friends,
The following machines are now offered on our CNCzone.com online marketplace for used machines:
13 Metal working machine
1 Industrial washing machines
1 Centre lathes
1 CNC-lathes (2-axes)
1 Vertical borer, single column
2 Horizontal turning and machining centers
3 Universal milling machines (knee type)
1 Bed milling machines (moving table)
1 Bench and Column type drilling machines
1 Rapid radial drilling machines
4 Machining Centers (Vertical)
3 Machining Centers (Horizontal)
1 Shaping machines
1 Broaching machines (Vertical)
1 Grinders
1 Surface Grinders with vertical spindle
1 Surface Grinders with horizontal spindle
1 Rotary table surface grinders with horizontal spindle
1 Double sided grinders
2 Double grinding wheel machine
3 Thread & Worm Cutting Machines
4 Horizontal Gear Hobbers
4 Gear Tester Combination
1 Spline Rollers
1 Accessories/Parts/Tooling
6 Circular Sawing Machines
1 Band Sawing Machines (Horizontal)
1 Band Sawing Machines (Vertical)
1 4 Column Single Action Presses
1 H-Frame Straightening Presses
1 Handoperated Lever Presses
2 H-frame eccentric presses
1 Coiler straightening machines
3 Sheet-straightening machines
1 Plasma Cutting machines
1 Sheet metal gang slitting line
1 Wiring and spring coiling machines
56 Accessories - Welding
1 W E L D I N G
1 Welding, Electric
1 Vertical Digitizing and Coordinating Measuring machines
2 Roundness, shaft and production measuring equipment
1 Surface- and die spotting plates
1 Through Feed Flat Bed Linishing , Brushing Machinery
1 Industrial Ovens
2 Reelers and decoilers
Kind regards,
CNCzone.com Management
