Hello CNCzone.com Friends,
The following machines are now offered on our CNCzone.com online marketplace for used machines:
5 Metal working machine
1 Molding machines
1 Lathes
11 Centre lathes
3 CNC-lathes (2-axes)
1 CNC lathes (3 axes)
1 Facing Lathes
1 Vertical borer, single column
6 Universal milling machines (knee type)
4 Toolroom / tool die milling machines
1 Bed milling machines (moving table)
3 Bench and Column type drilling machines
2 Radial drilling machines
1 Rapid radial drilling machines
1 Deep Hole drilling machines (Horizontal)
5 Machining Centers (Vertical)
7 Machining Centers (Horizontal)
2 5 Sides Machining centres (Vert/Hor)
1 Broaching machines (Vertical)
1 Borers (Table type)
1 Surface Grinders with vertical spindle
2 Surface Grinders with horizontal spindle
2 Cylindrical Grinders
1 Internal Grinders
2 Rotary table surface grinders with horizontal spindle
1 Tool grinding machines
3 Double grinding wheel machine
1 Centre hole and valve Grinders
1 Cam and profile Grinders
1 Lapping machines
1 Thread & Worm Grinders
1 Horizontal Gear Hobbers
1 GEAR SHAPERS
1 Sound & Noise Testers
1 Gear Tooth Chamfering, Pointing & Rounding Machines
4 Circular Sawing Machines
2 Band Sawing Machines (Horizontal)
1 H-Frame Straightening Presses
1 Car Body Presses
1 High speed Punching machines
3 Sheet Metalforming machines
1 Hydraulic Folding machines
1 Mechanical driving Swager machines
36 Accessories - Welding
2 Chucks, hydraulic
1 Punching units and tools
1 W E L D I N G
1 Conveyers & Cranes
3 Other
1 Other Measurement Machines
2 Pressbrakes
Kind regards,
CNCzone.com Management
