- Platform CNC Router/Plasma Cutter/3D Printer/Plotter/Etc - No Longer Available
This is a new Platform CNC machine built from a kit purchased from Brian Oltrogge...the designer of the machine as well as parts from www.mcmastercarr.com, www.cncrouterparts.com, www.ugracnc.com and www.amazon.com. These machines can be used as a CNC Router with either a standard router or spindle (I have a 0-24,000 RPM watercooled spindle included in this package.) to mill wood, aluminum, plastic, foam, etc. The machine can be converted to a CNC Plasma Cutter with a waterbed to CNC cut steel, etc. It can be converted to a 3D printer and even a plotter for a pen or hobby knife to cut out letters in vinyl or paper, etc. It is a very versatile machine. It is currently set up for milling wood and aluminum up to 48" long x 30" wide x 5.5" tall. I am including four brand new bits to mill wood and aluminum.
You can read all about this machine and see how others are using them here:
http://www.cnczone.com/forums/diy-cnc-router-table-machines/153486-grunblau-rustbelt-platform-cnc-build-log.html
and here:
http://www.grunblau.com/PlatformCNC.htm
Here are the machine Specs (as built)
30" X 48" X 5.5" Cutting Area (300 IPM)
Fast-Travel Precision Acme Threaded Rods
Gecko G540 4-Axis Stepper Motor Driver
Precision CNC Bent 3/16" Linear Rails
Optional Dual or Single Drive Y-Axis
48V 12.5A Switching Power Supply
4 High-torque NEMA 23 320 oz-in Motors
DumpsterCNC Acme Anti-backlash Nuts
Large Twist Lock E-Stop Button
Dual 80MM 120V Cooling Fans
Front Mounted Power Receptacle and Switch
Laser Cut Steel and Aluminum Construction
Rubberized Non-Slip Adjustable Machine Feet
Optional Function Based Insert System
220V/24000 RPM Water Cooled Spindle with ER20 Collet
120V Water Pump/ Water Radiator/ Tubing for Water Cooled Spindle
Complete set of ER20 Collets ($100 by themselves)
4x Amana Bits ($120 total 2x for wood and 2x for aluminum)
Rolling storage cart with locking casters. ($300 in parts)
Dell Windows XP Professional PC with 20" Monitor, Keyboard and Mouse
Mach 3 CNC Software Included ($200)
All Cables/Parts needed for turnkey system.
This machine has been tested and all axis work fine. I have not used the machine to cut anything yet and due to a recent move, I have not had time to set it all up and run the 220V for the spindle. If you need to have this item shipped...I can break it down into individual boxes and ship it anywhere in the world but it would need to be paid for upfront. It would cost around $250 to ship anywhere in the U.S.
I have a little over $6000 invested in the machine and the stand, computer and software and I have receipts for 95% of everything for your records and warranty.
I am willing to drive to meet someone in person up to a few hours from 30017. but I will need a non refundable deposit before I load it up and drive somewhere. Please feel free to contact me with any questions.
List Date: 8/1/2014
For more info, click here to view the original listing: Platform CNC Router/Plasma Cutter/3D Printer/Plotter/Etc
This item is no longer available.
- You may not post replies
- You may not edit your posts
Forum Rules
