Results 1 to 3 of 3
Thread: plotting against a .dxf file
    Nov 2005
    I am looking to a editor and verifier program to test out nc code. I need to test the code against a imported .dxf file to confirm geometry is not violated.
    Does Ncplot have the ability?
    Apr 2006
    uk
    I've done it the other way, and saved a plotted program as a dxf, and exported that from ncplot into autocad overlaying it to see if there were any errors.
    It works really well.
    Gold Member MetLHead's Avatar
    Mar 2003
    NCPlot does allow you to specify a DXF file to be used as a background to your backplot. On the machine configuration go to the viewport page and you will see a spot where you can specify the file you want to display.
    Scott
  1. Mirror Plotting
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 01-05-2010, 03:01 AM
  2. Offline Plotting
    By JohnJW in forum Haas Mills
    Last Post: 04-07-2009, 11:39 AM
  3. Printing/plotting Services?
    By imsofaman in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 08-29-2008, 09:40 PM
  4. plotting questions
    By HIRAH in forum NCPlot G-Code editor / backplotter
    Last Post: 10-31-2006, 07:30 AM
  5. Problem with 4th Axis Plotting
    Last Post: 10-19-2006, 07:35 AM
