Results 1 to 5 of 5
Thread: Mirror Plotting
    Dec 2004
    U.K.
    Mirror Plotting
    Hi again Scott,
    In our shop we have some haas machines, when plotting there is only an option to change mirror M CODE. These machines use G CODE, but not same as fanuc...
    G50.1 Mirror Image Off = G100 HAAS M/C
    G51.1 Mirror Image On= G101 HAAS M/C
    could you maybe add this as a config option on your ever growing todo list please if poss.
    To check the flow of program is correct we just been changing g code to fanuc format and then back before going to machine.
    Thanks.. Keith
    Gold Member MetLHead's Avatar
    Mar 2003
    Keith,
    What's the format of the Haas G100/G101 commands?
    Thanks,
    Scott
    Dec 2004
    U.K.
    Quote Originally Posted by MetLHead View Post
    Keith,
    Thanks,
    Scott
    Hi, the format is same as fanuc, just different G-CODE.
    G51.1 Y0.
    = G101 Y0.
    Thanks,
    Keith.
    Mar 2003
    Keith,
    Here's an updated Haas Mill configuration that supports G100/G101. I just added these two as G-Code macros. Unzip the attached file into your "\Program Files\NCPlot v2.xx\Config\" folder, it replaces the existing Haas Mill configuration.
    Thanks,
    Scott
    Attached Files Attached Files
    Dec 2004
    U.K.
    Thumbs up
    Keith,
    Thanks,
    Scott
    Thanks, that works a treat, I never thought of doing it that way with the custom g codes. I have used them for some other things. Very clever.
    Keith.
    1. Offline Plotting
      By JohnJW in forum Haas Mills
      Last Post: 04-07-2009, 11:39 AM
    2. Plotting a sample program.
      By rsm169 in forum NCPlot G-Code editor / backplotter
      Last Post: 03-16-2008, 08:36 PM
    3. plotting troubles? solution here
      By casella in forum Product and Manufacturer Announcements
      Last Post: 02-22-2008, 05:10 AM
    4. plotting questions
      By HIRAH in forum NCPlot G-Code editor / backplotter
      Last Post: 10-31-2006, 07:30 AM
    5. Problem with 4th Axis Plotting
      By TURNER in forum NCPlot G-Code editor / backplotter
      Last Post: 10-19-2006, 07:35 AM
