Results 1 to 3 of 3
Thread: Specify starting endpoint in dxf import ?
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    Question Specify starting endpoint in dxf import ?
    Hi Scott
    Is there a way to specify which endpoint the chaining starts at ? Or more importantly where the toolpath starts.
    I have tried "sorting" and reversing chain but cannot get it to start in a different place.
    I am using Solid Edge as my CAD and saving my drawings as dxf , I did not see any way to specify chains or endpoints there.
    Scott
    Gold Member MetLHead's Avatar
    Mar 2003
    Hi Scott,
    This ability was just added for version 2.20 beta 5. This version has a new button on the toolbar that let's you pick where you want the chain to start. It also shows you on the viewport where the chain start points are as well as the direction of the chain. Plus you can now apply some translations to the drawing such as shift, mirror and rotate.
    Thanks,
    Scott
    Apr 2006
    Medina , Ohio USA
    WOW
    Damn Scott....you're good !!
    Got it , works great !
    you da man
    Thanks a bunch
    Scott
  1. Can you import a...
    By brianklein in forum Mastercam
    Last Post: 11-05-2009, 05:52 PM
  2. import
    By Pecker in forum Surfcam
    Last Post: 07-17-2008, 02:49 PM
  3. DXF Import
    By Martin Long in forum Syil Products
    Last Post: 07-13-2008, 11:38 PM
  4. Need Help!- STarting NEw project - Need Serious Help to Understand PArts before starting
    By osix in forum DIY CNC Router Table Machines
    Last Post: 06-30-2008, 04:54 PM
  5. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 08:08 AM
