Page 1 of 2 12 LastLast
Results 1 to 12 of 19
Thread: NCPlot v2.20 beta 2 now available
    Gold Member MetLHead's Avatar
    Mar 2003
    These beta versions are for testing only and are intended to help us work out problems before updates are released. To download, go to www.ncplot.com and click the NCPlot v2 link.
    NCPlot v2.20 BETA 2 Release Notes
    September 20, 2009
    General
    If the Preferences dialog is open and changes have been made to the settings then NCPlot will prompt you to save these changes before shutting down.
    Fixed the shortcut keys on the 'Find' dialog for the 'Find What' and 'Replace With' settings.
    Shortcut keys assigned to the items on the 'File' menu were appearing next to the wrong menu item. This is fixed.
    Fixed the error message when trying to import settings 'Setup / Import Settings'.
    When NCPlot was launched by double-clicking an associated file it gave an error message that the file was already open. This has been fixed.
    Added a 'Close All' menu option to the 'Window' menu.
    If there more documents open than the 'Open Files' toolbar can display you can now click the small band at its right end to see a list of the non-visible document names.
    Window Tiling
    Added a window tiling option called 'Tile' to the 'Window' menu.
    Changed the behavior of the 'Tile Vertically' and 'Tile Horizontally' tools. These tools will now always arrange the documents in their respective directions regardless of how many are open.
    Added an option to the Preferences dialog called 'Auto Arrange Files'. When this option is checked the open files will re-tile themselves whenever a file is opened or closed. The last selected tiling option from the 'Window' menu is used.
    Viewport
    The viewport can now only be docked on the left or right side of the application window. It can still be detached from the application.
    Fixed a problem with the viewport scroll bar. Dragging the scroll bar back and forth several times would eventually lead to an error message.
    Comments are welcome! Let me know if you have any trouble.
    Thanks,
    Scott
    Dec 2004
    U.K.
    Hi Scott, a few notes for you to browse....
    1) When multiple files are open, could you make the viewport auto refresh to the selected program as you switch between them. If when programs are first opened and plotted a machine config is selected, maybe you could store this for each open file so when you flick back to that program the m/c config is loaded and plot refreshed. If a plot has not been performed before another file is opened set to a default. I.E for each open file, remember last selected config used when this file was active.
    2)If the viewport is undocked and then closed, to get it back you have to right click toolbar and recheck viewport. Could maybe add a toolbar button to do this.."Show viewport"
    3)I have noticed when using keyboard to step through plot ie press 's' forward and 'b' backward if you hold the s key down plot steps quickly through program but if you press and hold b program reverses quickly but does not refresh graphics...ok on single presses.
    (did this on previous version not a new problem)
    4)When using the measure function on the graphics cursor shows a crosshair,
    previous versions showed a box around the intersect points, i prefered that was clearer.
    No major issues, well done again.
    P.S. Hows the 3d going?,(this is what im waiting for). Is this change getting ready for implementing that?
    Cheers
    Keith.
    Jul 2008
    CANADA
    havent downloaded the newest version yet, but also in the last one i found happened once in a while(25+ times), was when you started ncplot, went to file then opened any program, nc plot just sat there and did nothing. not a big problem you just had to do it again. dont know if that was fixed. or once again just me.
    Mar 2003
    Quote Originally Posted by TURNER View Post
    If you turn on the auto refresh option under 'Draw / Auto refresh viewport' it will refresh the viewport when you switch files. Switching configurations may be a bit more difficult, I'll look into it.
    This brings up a good point... figuring out how to turn toolbars back on is not obvious. I'm thinking that a toolbar menu might be in order.
    I hadn't noticed this, thanks for pointing it out.
    I can change it to whatever, I was just trying to make it more visible.
    Cheers
    Keith.
    The 3d has been on hold while I've been working on the last couple of updates, but as soon as this update is finished then finishing the 3d will be next.
    Thanks,
    Scott
    Mar 2003
    Quote Originally Posted by yongchiprsnapr View Post
    I haven't seen this happen so I can't really offer much help. The only thing I can suggest is to try the latest version (now v2.20 beta 2). If it is still a problem in this version then let me know what OS version you are running so I can try to duplicate it.
    Thanks,
    Scott
    Dec 2004
    U.K.
    Hi again Scott,
    May have found another little 1. When you open a program or switch between programs ncp shows a text control fill docked. If you have the main window NOT maximized and you resize it the text control does not refresh docked in the left panel. Maybe you didnt want it to do this. Ill leave it with you, see what you think.
    ....Keep it up
    Keith.
    Mar 2003
    Thanks Keith, I somehow missed that.
    Scott
    Dec 2004
    U.K.
    Quote Originally Posted by MetLHead View Post
    Scott
    Hi, just noticed if you double click title bar of file this docks it, like the graphic window, is ok then when resizing, it stays fully docked.
    Guess its just a bit of getting used to how things work. My previous post was in tile view i think.
    Thanks Keith.
    Dec 2009
    Hello All,
    I am a new Forum user, but have had NC Plot for some time now.
    Some of the macros I try to plot use G32 commands and NC Plot doesn't seem to recognize them?
    It seems to recognize G92 just fine.
    Do any of the latest udates fix this?
    I purchased version 2.0, and it states that it covers all updates to version 3.0
    How do I upgrade to the latest version?
    Thank You in advance for any help!
    Mar 2003
    Hello,
    NCPlot doesn't currently come with a cycle for G32, but one can be added without updating. I've attached a G32 cycle to this message that I think will work, you'll need to try it out and let me know if it is what you need. To install this cycle:
    1. Unzip the attached file and copy it to the folder for your current configuration.... if you are using the configuration "Lathe Diameter" then its folder will be at "\Program Files\NCPlot v2.07\Config\Lathe Diameter".
    2. Open the machine configuration in NCPlot and go to the "G / M Codes" page. Where it says "G-Code macros" type in "G32" and hit enter. Then save the configuration.
    Give this a shot and let me know if this helps.
    FYI: To update to the latest version, uninstall your current version and then download and install the current version from the website. The current version is v2.07, with v2.20 currently in development.
    Thanks,
    Scott
    Attached Files Attached Files
    Dec 2009
    The G32 isn't an actual cycle. More a spindle rotation sync with the given feedrate for the axis movement per line.
    It just errors when it reads the G32
    I could replace them with a G1, or just take the G32's out, and then it plots just fine.
    Perhaps what you sent me will work, I'm just concerned as I'm using most of those variables you are used in my macro. Not sure if it will replace the values I'm using.
    Mar 2003
    The local variables in the G32 G-Code macro will not replace any variables outside of the macro, so you should be ok there.
    Scott
  • Page 1 of 2 12 LastLast
    1. NCPlot v2.05 beta 2 now available
      By MetLHead in forum NCPlot G-Code editor / backplotter
      Last Post: 05-16-2008, 11:00 PM
    2. NCPlot v2 beta 15 now available
      Last Post: 11-08-2005, 09:11 PM
    3. NCPlot v2 beta 14 now available
      Last Post: 10-25-2005, 08:49 PM
    4. NCPlot v2 beta 13 now available
      Last Post: 10-22-2005, 01:05 PM
    5. NCPlot v2 beta 12 now available
      Last Post: 08-20-2005, 09:23 PM
