Results 1 to 2 of 2
Thread: NCPlot v2.07 beta 2 now available
    Gold Member MetLHead's Avatar
    Mar 2003
    These beta versions are for testing only and are intended to help us work out problems before updates are released. To download, go to www.ncplot.com and click the NCPlot v2 link.
    It's been awhile since the last update and I appreciate everybody's patience!
    NCPlot v2.07 beta 2 Release Notes
    July 19, 2009
    Updated since the last beta:
    The SpaceNavigator works much better with large files. It now responds the same as the mouse controls.
    Added a setup dialog for the SpaceNavigator. This dialog allows you to customize the orientation and sensitivity of the rotate, pan and zoom controls. Also added the option to export these settings on the "Setup / Export Settings" dialog. Likewise the "Setup / Import settings" tool will import these new settings.
    The entities created by the auto radius and auto chamfer commands were not being given the correct tool number, this is fixed.
    When the M98 subprogram format is set to use the K address as the repetition count the canned cycles will also recognize the K address as the repetition count.
    Added the ability to drag text within the edit window. You can now select a region of text and then click and drag it within the edit window.
    Enjoy!
    Scott
    Jul 2006
    Scott,
    The improvements in the space navigator are very nice - it's great to have NCPlot act like the other programs I use the navigator with!
    Dave
  1. NCPlot v2.05 beta 2 now available
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 05-16-2008, 11:00 PM
  2. NCPlot v2 beta 16 now available
    Last Post: 11-15-2005, 09:24 PM
  3. NCPlot v2 beta 15 now available
    Last Post: 11-08-2005, 09:11 PM
  4. NCPlot v2 beta 14 now available
    Last Post: 10-25-2005, 08:49 PM
  5. NCPlot v2 beta 13 now available
    Last Post: 10-22-2005, 01:05 PM
