Results 1 to 5 of 5
Thread: Can't set NCPlot as default program
    Registered Scott_M's Avatar
    Apr 2006
    Medina , Ohio USA
    Hi Scott
    I have been having this trouble for a while now on both 2.05 and 2.06.
    If I browse to a .nc file and right click / open with / set default program
    and browse to the 2.06 folder and click on the .exe. It does not appear in the choice list. I have NCPlot installed in the default location C:\Program Files\NCPlot v2.06\NCPlot.exe . But the only thing I can use is notepad ? I have had no trouble in the past with versions earlier than 2.05.
    I'm confused
    OS is Vista ultimate.
    any insight would be helpful.
    Scott
    Gold Member MetLHead's Avatar
    Mar 2003
    Hi Scott,
    I had the same problem a while ago. I'm not sure if was this computer or a different one, but it worked on this one. My suggestion would be to run a registry cleaner like ccleaner (which is free) and try it again. I don't think its an issue with NCPlot, I think its probably an issue with Windows.
    Thanks,
    Scott
    Apr 2006
    Medina , Ohio USA
    Thanks Scott
    I kind of thought it was a windows problem as well. But by putting it here I can draw on the experience of all.
    I will run ccleaner and report back.
    Scott
    Apr 2006
    Medina , Ohio USA
    Resolved
    Thanks again Scott !!
    CCleaner did the trick.
    Scott
    Mar 2003
    Scott,
    That's great! We'll thank ol' Bill G. for that one...
    Scott
    1. default units
      By canadamaxxer in forum Solidworks
      Last Post: 10-07-2010, 02:05 PM
    2. V8 default values
      By mjp in forum Mastercam
      Last Post: 01-01-2009, 09:22 AM
    3. Default SL-20 parameters question?
      By PaintItBlue in forum G-Code Programing
      Last Post: 11-01-2007, 06:48 PM
    4. NCPlot as default editor in Mach 2 ( Problems )
      By Scott_M in forum NCPlot G-Code editor / backplotter
      Last Post: 04-01-2007, 06:11 PM
    5. Default Comms Program
      By Rekd in forum Mastercam
      Last Post: 06-11-2003, 09:29 PM
