Hi Scott,
May have found another bug that wasnt there previously. I am running the beta version 2.6.0.38 and have found through the Calc menu the Measure function is now not working.
Keith.
Arrgh... I found a pretty serious bug so it looks like we will have one more beta version.
www.ncplot.com
Only two changes were made for this version:
Fixed a bug in the subprogram search routine that was introduced in the last beta.
The help file has been updated with all the current changes.
Thanks,
Scott
Hi Scott,
Keith.
Keith,
You're right, thanks for reporting this.
Scott
Scott,
Any plans on developing a toolbar (terminology) to allow users to develop a tool list and/or setup sheet from the G&M code file?
The run time estimation report is the closest thing to this right now. If you open the run time estimation window "Tools / Run Time Estimation" then click "Generate Report" this gives you a machining time estimation per tool.
What other information do you think should be on this report?
Thanks,
Scott
The ability to generate a setup sheet. See the attached example.
Does this tooling information get extracted from the program? Do you have a sample program with this information in it?
Thanks,
Scott
Scott,
Here's the sample you requested.
Thanks for the sample program! I've got this feature request on the list now, so I'll be taking a look at it.
Thanks,
Scott
