Without looking too closely it sounds about right if you have zero's in the work offset.
To get numbers in the offset you have to make the existing number gray by selecting with the mouse or hitting enter. Then put the number in and hit enter again. When all the numbers are showing you need to hit the apply button.
I have not had much luck saving and/or recalling offsets.
LinkBack URL
About LinkBacks
