Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 03-03-2008, 08:27 AM
duenow is on a distinguished road
Something broke in V2.04
In V2.03 loading a Fanuc lathe program the way the machine sends it back would load it in text & run fine one line as one line.
V2.04 only loads it all jumbled together & will not run.
[IMG]<a href="http://s267.photobucket.com/albums/ii305/dobedave/Haas/?action=view&current=fanuc.jpg" target="_blank"><img src="http://i267.photobucket.com/albums/ii305/dobedave/Haas/fanuc.jpg" border="0" alt="Fanuc file"></a>[/IMG]
Old 03-03-2008, 08:28 AM
Sorry image didn't work, try again.
http://i267.photobucket.com/albums/i...Haas/fanuc.jpg
Old 03-03-2008, 10:00 AM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
OK, I found something else that was broke too, so I'll fix this at the same time.
Thanks,
Scott
Old 03-03-2008, 07:05 PM
MetLHead's Avatar
Gold Member
This should be fixed now. I've uploaded the updated file, so re-download it and give it a try.
Thanks,
Scott
Old 03-04-2008, 07:00 AM
TURNER is on a distinguished road
Hi Scott,
Ya having a bit of bother ?. Ive found another problem with the re-released V2.04. Look at this snippet got loads of crap in but get no format errors when plotting. Your last version used to pick up on this sort of thing. It looks like it is just ignoring, also if in Setup/Preferences/stop at M00 is ticked if there is an M on its own or just in a word it throws M00 program stop msg.
OAA12
G17G0G99G54
T1M6
G97S1000
G0X100.Y100.
G0Z2.
G1Z0.
M(TTTT
G0Z5.(TTT
GARBAGEFORMAT123
look i can write any thing i like in here
G0X200.Y200.
M30
Might be best like you said, to beta test updates before full release.
Not a major problem can just use previous version if any problems.
Have Fun
Turner
Old 03-04-2008, 07:34 AM
MetLHead's Avatar
Gold Member
Turner,
This is a result of changing the way addresses are interpreted:
The backplotter will now accept addresses with no corresponding value.
G00 XYZ
This will be interpreted as:
G00 X0 Y0 Z0
From the sounds of it, I need to make this an option that can be turned on or off. In your case you would want it off in order to catch bad G-Code, but turning it on will allow NCPlot to plot code from a wider variety of controls. This is because it will cause NCPlot to ignore keywords or codes that it doesn't understand.
Yes, it's tough to make sure everything works before release.
Thanks,
Scott
Old 03-04-2008, 09:01 AM
Thanks,
Scott
That fixed it Scott. The lathe time cycle is still way off gives a 34M time on a job that is less than 1m. But that's ok I can do without that. The mill time cycle is right on.
Old 03-04-2008, 09:29 AM
MetLHead's Avatar
Gold Member
I suspect the cycle time issue has something to do with the default feed mode that you have selected (IPM/IPR). Or, it could be off if you're using any of the canned cycles. I know this has been brought up before, but I don't think I ever came up with a good answer for it. If you can, send me a sample program along with the actual cycle time and I'll try to pin this down.
Thanks,
Scott
Old 03-04-2008, 10:02 AM
Ok, says cycle time is 37M 19S, it's 1M 14S
&HE:%
:0178
G20
G65P9150H1.(SET FOR 50-90-PSI)
(BELMED)
(P/N A-70-000-12 JOB->O178N)
N2(-FEED-STOCK-T0200)
G97
M98P1(SAFESTART)
G04T0202
X0.Z1.M09
/X0.Z-0.550
/M21
/G04U0.3(1/2SECDWELL)
/Z0.020
/G04U1.
M22
M98P2(SAFEEND)
N3(TURN-ISCAR-.008R)
G97S1500M13
M98P1
G04T0303
S3000X0.300G00Z0.150
Z0.
G99G01X-.060F0.001
X.0425F0.004
X0.085Z-0.0063F0.002
X0.100Z-0.1911F0.002
X0.139Z-0.2412
G00Z.010
X0.
G01Z.001F0.004
X.0385
X0.054Z-0.0085F0.001
X.0698Z-0.1926F0.0006
X0.138Z-0.2478F0.002
Z-.434F0.003
X.271Z-.530
M98P2
N5(-THD-COMPOUND-CUT-T0500)
G97M13S3000
M98P1(SAFESTART)
G4T0505
X0.311G00Z0.100
Z.100
/G76P000060Q0020R0.0001
(P=SPRING-PASSES.P--=PULL-OFF-DIS.P----=COMP-ANGLE)
(Q=FIRST-PASS-DEPTH.R=FINISH-PASS-AMOUNT)
/G76X0.1487Z-.950P0192Q0090R-0.0012F0.03125
(X=ROOT-DIA-Z=LENGTH-P=SINGLEDEPTH-Q=1STPASSDEPTH-R=TAPER)
M09
S1500M98P2(SAFESTARTENDPRG)
M05
M98P1(SAFESTART)
G04T0202
X0.Z1.
/X0.Z.050
/M21
/Z0.230
/G04U1.
M22
M98P2(SAFEEND)
N4(GROOVE-.025-T0404)
G97S1500M13
M98P1
G04T0404
X.227G00Z.300
S3000Z-1.010
G99G01X0.167F0.0025
G04U0.2
X0.189
Z-1.011
X0.167
X0.189
Z-1.020
Z-1.005
G00X.227
M09
M98P2
N2(FEED-1.27-LONGER)
M05
M98P1
G4T0202
X0.Z.300S500M09
/X0.Z.250
/M21
/G04U0.3
/Z1.793
/G04U1.
M22
G00Z3.500
M01
N1(-CUTOFF-T0100)
G97M13S1500
T0000
G4T0101
X.247G00
S3000Z-.674G00
G99G01X.157F0.0025
X.247G00
Z-.629
G01Z-.674X.1570F.002
X0.100F0.002
X-0.010M26F0.0015
X-.060F0.004
X.247G00M09
M25
S1000M98P2
/M31
M30(-PRG-END)
Old 03-04-2008, 10:56 AM
MetLHead's Avatar
Gold Member
OK, I ran your sample with the default "Lathe Diameter" config and this is what I get.
Thanks,
Scott
Name:	Cycle Time.JPG‎
  #11   Ban this user!
Old 03-04-2008, 12:18 PM
Thanks,
Scott
now that is strange here is what I get. What's wrong running XT
http://i267.photobucket.com/albums/i.../Haas/178N.jpg
  #12   Ban this user!
Old 03-17-2008, 01:47 PM
metLHead did you ever figure this out?
About my time cycle?
Don't know what I broke on IH CNC Shepard Industrial Hobbies (Support forum) 3 09-27-2007 01:15 PM
she,s a broke eh corrie Machine Problems, Solutions , Wireless DNC, serial port 3 09-12-2007 06:08 PM
r-8 locating pin broke jarr88 Benchtop Machines 3 08-26-2007 08:32 PM
Broke a pin off in the PCMCIA port... pdoherty Daewoo/Doosan 11 08-23-2007 04:59 PM
HL1 Counterbalance Spring Broke Geof Haas Lathes 2 07-26-2007 01:37 PM
