Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 02-28-2008, 11:10 AM
TURNER is on a distinguished road
Local Variables?
Hi Scott,
Possibly another problem with local variables, they seam to clear on M99, but this does not happen on the m/c.
Is this set on a parameter on the m/c?
O0001(NCPLOT CLEARING VARS ON M99)
G65P2A10.B20.
(NEXT LINE SHOULD MOVE TO X30.0 )
( BUT GOES TO X20.0 AS #1 HAS BEEN CLEARED )
G0X[#1+20.0]
M30
O0002
G21G55G17G0
T1M6
G40G0X0.Y0.
Z2.
X#1Y#2
M99
thanks
Turner.
Old 02-28-2008, 09:23 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Hi Turner,
It seems odd that your control *wouldn't* clear the local variables on M99. The reason that they are called "local" variables is because they are only valid for the sub that they are used in. Say for example your program O0001 used variable #3 as a loop counter. Let's also say that your program O0002 also used variable #3 for something. The idea is that program O0002 can use this variable *without* disturbing the value of #3 that program O0001 is using. So after the M99 in O0002, the value in #3 that program O0001 sees is the same is it was before the subprogram call, even if program O0002 also used #3.
What control are you seeing this on?
Thanks,
Scott
Old 03-03-2008, 07:25 AM
Originally Posted by MetLHead View Post
Hi Turner,
Thanks,
Scott
Sorry you are right, i was wrong. The control does not clear on M99, it was a new program i was writing and testing in NCPlot, we had previously been using common variables shared between subprogs, i was trying a new method using G65 and only passing the variables needed for certain changes. Ive not used local variables before and wasnt aware that they had levels for each prog. Never mind, Ive learned somthing new anyway.
Turner
local variables of a macro sinha_nsit Fanuc 8 01-16-2008 07:19 AM
Local Suppliers jhudler Suggestions for the CNCzone.com site. 0 11-17-2007 09:12 PM
Local variables jorgehrr G-Code Programing 4 02-19-2007 04:03 PM
any Australians in here with local suppliers dave05 DIY-CNC Router Table Machines 6 09-05-2006 06:00 PM
G65 local variables help FanukRC G-Code Programing 7 07-25-2006 07:00 PM
