Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 02-07-2008, 04:26 PM
Andre' B is on a distinguished road
Some strange stuff with local vars.
Plotting this program it seems to think variable #32 is always zero.
If I replace the three uses of #32 with #27, thru #31 it works the same way.
But if I replace them with #26 or #25 it works as expected.
I did not check all the numbers less then #27 but I expect they would also work.
Variable #99 does not work but #100 does so I expect any global would work but only locals less then #27 would work.
I have not tried running on a actual machine yet either.
Code:
O9110
#6=0.125(INSIDE CORNER RADIUS)
#7=1.100(SMALL ROUGH OD)
#8=1.000(SMALL FINISHED OD)
#9=0.062(CHAMFER SIZE)
#10=0.006(END FACE MATERIAL)
#11=0.888(LENGTH OF SHOULDER)
#12=0.520(ID FOR FACE CUT)
#13=0.0156(TOOL NOSE RADIUS)
#14=0.0000(TAPER COMP)
#15=0.0010(SECOND FINISH PASS)
#33=FUP[[#7-#8]/0.020](TEMP,NUMBER,OF,PASSES)
#32=0.010
G0Z[#10+0.100]
G0X[#7+2*[#6]+0.200]
G73U[#7-#8]W[#33*0.0001]R#33(MATERIAL,AND,PASSES)
G73P31Q32U0.0010W0.0000S350F0.0030
N31G0X[#8+#15]Z[#10+0.010]S450F0.0010
G1X[#8+#14+#15]Z[-#11+#6-#13]
G2X[#8+#14+#15+2*[#6-#13]]Z[-#11]R[#6-#13]
N32G1X[#32+#8+#14+#15+2*[#6-#13]]
G70P31Q32(FINISH,PASS)
#15=0.0
#32=2.000-[#8+[2*#6]](CLEANUP,FULL,FACE)
G0Z0.200
Old 02-07-2008, 07:55 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Andre',
I tried your program, but I am not seeing what you describe. Do you get the same results when you plot it from the variable display window?
Scott
Old 02-08-2008, 08:41 AM
Yep get the same results.
Here are some screen shots of using variable #32, the rough and both finish passes stop at the end of the 0.25 radius.
And the second that works the way I think it should when using #26, the rough and first finish pass stop 0.010 out from the end of the 0.25 radius and the second finish pass goes out 2.000 from the end of the radius.
Upload is not working, will try later.
Old 02-08-2008, 11:16 AM
MetLHead's Avatar
Gold Member
Andre',
After looking at this some more, I've managed to find the problem. NCPlot handles the G70 cycle as a subprogram and must pass the local variables to it. However, only the first 26 variables are being passed.
Thanks,
Scott
Local Suppliers jhudler Suggestions for the CNCzone.com site. 0 11-17-2007 09:12 PM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 12:30 PM
Local variables jorgehrr G-Code Programing 4 02-19-2007 04:03 PM
G65 local variables help FanukRC G-Code Programing 7 07-25-2006 07:00 PM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 02:39 AM
