Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 02-05-2008, 12:43 PM
Andre' B is on a distinguished road
Argument Specification II
Does NcPlot handle sub calls using argument specification type II?
So all 33 parameters can be used.
Code:
G65 P9500 Ax.x Bx.x Cx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x Ix.x Jx.x Kx.x
Old 02-05-2008, 09:08 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Hi Andre',
No, it doesn't. Do you have a machine set up this way?
Scott
Old 02-06-2008, 10:46 AM
I have a programming project where I may need to pass in more parameters then are available with spec. I.
I believe it is not something that needs to be setup in the machine but just depends on how the order of the parameters in the G65/66 call line. At least that is what the manual says I have not tested it on the machine yet, need to find some time when it is not running parts.
I can use global vars. if I need to, I just do not like doing that unless they are actually being used globally.
A simple workaround I can use for testing in NCPlot is to put some code at the top of the sub to copy variables #901 - #933 to #1 - #33 and then put some similar code before each sub call in the main program to load up the 900 variables.
Since this machine does not have the optional variables it should just cause an error if the copy code does not get deleted before the program gets to the machine.
17PM-H311-P1 specification dbunic Stepper Motors and Drives 10 11-26-2010 01:46 AM
Forum Bug- Missing Argument ger21 Forum Questions or Problems 25 03-19-2008 04:22 PM
What is the specification of Stepper motor sanjiv Stepper Motors and Drives 5 03-13-2007 05:23 AM
R8 Spindle Specification (M1TR?) lmartin1001 Mechanical Calculations/Engineering Design 1 10-16-2006 02:13 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
