Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 12-13-2007, 11:37 AM
ArchieF is on a distinguished road
Macro Translator
Hi Scott,
using the "Holes on arc"-Macro for example creates new lines with X- and Y-coordinates.
If I want to have a subprogram-call at each position I add manually the line P#### M98 after each coordinate.
So I added the variable #50 to the dialog and in the macro after the line X#32 Y#33 the text P O#50 M98 to let the macro create the subprogram-call.
But the macro translator comes up with error messages :
wrong expression or unknown subprogram
Is there a way to let a macro write text into the main program like I described ?
Thank you,
Richard
Old 12-13-2007, 06:16 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Hi Richard,
There's no way to do this at the moment. I do have some changes planned for the macro translator that I wanted to include in the next update. This includes the ability to insert whatever text you want. This will be good for adding comments or other miscellanous code just like you describe.
Thanks,
Scott
Old 12-14-2007, 12:03 PM
Hi Scott,
I found a way to handle this problem meanwhile:
in the macro after the line X#32 Y#33 I add the line X9999 and with search & replace I can change it in the main program to P9999 M98 for example
Thank you,
Richard
Old 12-23-2007, 05:45 AM
Hi Scott,
could you add the ability to show an individual small drawing to each macro as graphical support to what the macro is asking for ?
Thank you,
Richard
Old 12-23-2007, 11:19 AM
MetLHead's Avatar
Gold Member
Hi Richard,
I actually did have this in there during most of the beta process. But it didn't get finished in time for release, so I removed it. All the code is still there, I just need to finish the graphics and re-enable it.
Thanks,
Scott
G code translator for Galil harrymen General CNC (Mill and Lathe) Control Software (NC) 12 12-04-2009 03:19 PM
Allegro A3986...Stepper Translator slp_prlzys General Electronics Discussion 2 06-07-2009 02:59 PM
WILDFIRE & 2001 to IGES Translator 64dodge PTC Pro/Manufacture 1 01-16-2008 08:56 AM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-09-2007 12:41 AM
DAKENG u-2 16f84 stepper translator vacpress PIC Programing / Design 2 12-13-2005 08:58 AM
