Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 12-07-2007, 10:23 AM
Andre' B is on a distinguished road
Pan and Zoom
Any way to assign hot keys to the pan and zoom window functions?
Old 12-07-2007, 05:55 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
Hi Andre,
When the viewport is active, these keyboard shortcuts are active:
Zoom Window - "Z" Key - Allows dragging a box around an area to fit into the viewport.
Zoom Extents - "X" Key - Fits the part drawing into the viewport, including rapid motions.
Zoom All - "A" Key - Fits the part drawing into the viewport, disregarding the rapid motions.
Zoom Selected - "F" Key - Fits only the selected entities into the viewport.
Zoom In - "C" Key - Increases the zoom magnification, making the part appear larger.
Zoom Out - "V" Key - Decreases the zoom magnification, making the part appear smaller.
Pan – “P” Key – Activates the viewport pan tool.
Step Forward – “S” Key – Draws the next motion block in the program.
Step Backward – “B” Key – Un-draws the previous motion block.
Measure – “M” Key – Activates the measure tool.
To make the viewport active, click the mouse inside the view area or press the "TAB" key. You can tell if the viewport is active because the view name is highlighted rather than greyed out. At the moment, these key assignments are fixed and not assignable.
Thanks,
Scott
Zoom Turbine Mastercam 11 05-17-2003 06:33 PM
