Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 10-15-2007, 09:56 AM
PaintItBlue is on a distinguished road
Nc PLot and Haas G71 G72 codes
I was wondering if there is a way to get NC PLot to display the cut paths, and cords for the cuts that make up a g71,g72 canned cycle for a Haas lathe?
Old 10-15-2007, 01:14 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
If you want to see all the roughing motion for the canned cycle, then the answer is no. This has been on my list of things to do for a long time and I don't know when it might get done. All I can say is that it will probably be done as an update to V2 rather than as a part of V3.
Thanks,
Scott
Old 10-15-2007, 03:28 PM
thanks for the quick reply, i guess that's what single block stop and haas graphics are for.
Gonna be ordering 1 or 2 licenses soon..
Old 11-28-2007, 02:00 PM
single phase's Avatar
single phase is on a distinguished road
I vote for the FANUC lathe double line G75 command set. It would be great to see this work as well as it does for the G90 and G94 commands.
Even without the G7X commands there is nothing out there that does this as well as NCPLOT! If you are setting on the fence about this application, go ahead and pull the trigger, you will be amazed at how much faster and accurately you can write g-code for you lathe.
With NCPLOT you can write code that is much faster and more to-the-point than code from any CAM tool out there.
Cheers
SF
Old 11-28-2007, 11:53 PM
CNCRim's Avatar
Well NCplot will not backplot G7x for you but if you willing to spend money then EditNC Ver 9 or later will.... It even backplot drill G8x milling cycle for you too.
Old 11-29-2007, 01:34 AM
Aren't there several applications by that name?
Old 11-29-2007, 04:47 PM
CNCRim's Avatar
There are many brand name you can choose from, and these software do offer 30days trial version, Predator nc, Cimco Editor. Check it out.
Old 11-29-2007, 04:55 PM
I have used Cimco and Predator, I trialed both of them before I found NCPlot. For what I do it is way better.
I thought you were talking about EditNC. It returns lots of hits from the search engine. None of which that I could find that refer to lathe work.
Do you have a link for the software you are referring to in post #5?
Cheers
SF
Old 12-03-2007, 08:57 PM
Another thing that would be absolutely stellar in NCPlot would be a graphic that shows the G42 command's actual position and recomputed position based on tool radius.
This would help the programmer determine if he got the G42 in the right place in the code and it is using the right quadrant.
Old 12-06-2007, 12:48 AM
CNCRim's Avatar
My EditNC come with surfcam package, you can try there.
  #11   Ban this user!
Old 12-08-2007, 01:42 PM
Dave1's Avatar
Dave1 is on a distinguished road
SP,
Can't agree with you more. I think Scott did an outstanding job on this, I use it all the time to verify my programs.
Dave
Cheers
SF
Schneider Machine
A force of one
NC Plot with Big Files tobyaxis NCPlot G-Code editor / backplotter 9 07-25-2007 03:53 AM
NC PLOT Question? TURNER NCPlot G-Code editor / backplotter 1 09-13-2005 05:15 PM
Haas HL-4 ERROR Codes altcan Haas Mills 27 09-13-2005 10:33 AM
NC Plot Discussion jonbanquer NCPlot G-Code editor / backplotter 15 07-23-2005 08:22 PM
Batch Plot?? CNCadmin Autodesk Software (Autocad, Inventor etc) 9 07-16-2003 12:02 PM
