| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
| NC Plot seems to choke on files that are over 60,000 Sequence Blocks. Then turns into a Non Responding Program. What can I do to prevent this? I have it set to change back plot colors with tool changes and Letter Addresses. If anything I'd like to keep the Back Plot Colors and get rid of the Letter Adderss Colors. BTW: The program it choked on was 183,434 Sequence Blocks, too big to post here. Any one have an Idea?
| Hi Toby, You can improve the load time on big programs by turning off the address coloring. This is the 'Colorize' option on the 'Edit' menu. When you load a large program, you can see loading progress in the status bar. First, you see a message that says "Formatting ... " and then it should begin to plot. One thing I've noticed, and I haven't figured out why or if I can do anything about it, is that there seems to be a long pause between the formatting and the plotting. If you wait though, it should begin to plot. One other option is to turn off the 'Plot file when loaded' option on the Preferences window. Then the file only plots when you refresh it manually. Thanks, Scott |
| Thanks Scott, That worked perfectly. Here is one of the Files Posted in BCC V2007. It was one of the files I had a problem with. I still use NC Plot to edit G-Code created from V2007 even though I have the Predator Virtual CNC Level 3. NC Plot will always be on every PC I own. It Kicks Butt You can't Beat NC Plots Price for Lathe and Mill Back Plotting.Cheers!!!!!!
I also noticed that the drilled holes and counter bores aren't in your back plot, Is there a reason for that or you didn't finish back plotting?
| The Flat Areas where done Manually due to some issues that haven't been fixed in BCC V2007. It came out nice though. Nice back plotter, have you seen NC Plot? www.ncplot.com
| Of course I know of NC plot. We are chatting on its dedicated forum I only tried it, it's amazing and it seems one of the best wire backplotter speaking of settings possibilities and features. But it's slow with big files to compare to Cimco edit for example... And I couldn't make it ouput a complete and nice DXF file as I do with my little tool |
#10
| Subs: YES (Fanuc and Heidenhain) Macro: NO Variables: YES with Heidenhain Lathes: YES 4th axis: YES (even 5th axis) Both are great softs and they have their strength. Cimco: editing/fast processing/good looking/tabbed windows/(basic) solid verify NC plot: Macro management/a lot of settings/entities database |
| NC Plot v2 Beta 5 | MetLHead | NCPlot G-Code editor / backplotter | 3 | 09-14-2008 05:20 PM |
| NC PLOT Question? | TURNER | NCPlot G-Code editor / backplotter | 1 | 09-13-2005 05:15 PM |
| NC Plot Discussion | jonbanquer | NCPlot G-Code editor / backplotter | 15 | 07-23-2005 08:22 PM |
| Batch plot? | CNCadmin | Autodesk Software (Autocad, Inventor etc) | 2 | 08-04-2004 08:52 AM |
| Batch Plot?? | CNCadmin | Autodesk Software (Autocad, Inventor etc) | 9 | 07-16-2003 12:02 PM |
