| NCPlot G-Code editor / backplotter Discuss NCPlot software here. |
An NCPlot update is now available for download. This update is free for registered users. This udpate can be downloaded at www.ncplot.com NCPlot v2.01 Release Notes May 1, 2007 General The backplotter now allows comma characters for the auto radius and auto chamfer commands ",R" and ",C". Made a change to the expression evaluator to allow square bracket comments to follow numeric values. For example: "M06[TOOL CHANGE]". This was causing an error. Fixed a problem with programs whose program number is designated with the colon character ":". This problem was causing some searched block numbers to not be found. This affected any G-Code or macro statement that required a search for a block number. Made a change to the Lathe G76 threading cycle to support plotting tapered threads. The viewport now allows deleting selected entities. Pressing the 'Delete' key will remove any selected entities from the display. This does *not* delete the corresponding blocks from the program. To restore the deleted entities, simply refresh the viewport. Machine Setup Added a setting to the 'Machine Type' tab that allows defining the default file types. This defines the types of files that are displayed when browsing for files to open or save. Added a setting to the 'Control Options 2' tab that allows defining the address used by the G04 dwell command. This setting defaults to the "X" address. Preferences Added an option that allows turning on or off the plotting of files when they are loaded into NCPlot. Added an option that will cause the viewport to zoom to extents when the view orientation is changed. DXF Import When using the "Z Increment" setting, under certain conditions the last entity in the drawing would not be converted to G-Code. This is fixed. Added support for ELLIPSE entities. Imported ellipses are broken into line segments when read. Now correctly reads closed Polylines. Fixed a problem in the chain sorting tool. If the last chain was a single entity, it would disappear after sorting. Fixed a problem in the chain reversal tool. In some cases an unselected chain would reverse along with the selected chain. The sorting tool now allows defining the start point for sorting. To do this simply select one entity that is part of the chain you would like it start from. Macro Stepping Helical arcs were not being drawn when plotted from the 'Show Variables' window. This is fixed. Enjoy! Scott Last edited by MetLHead; 05-01-2007 at 09:58 PM. |
| Scott, You always come through for us, THANKS!!!!!!!
| Hi! I found this thread on a google search... So..... consider this a feature request... I'd love a program that strips out duplicate movement information... In other words: G01 X1 Y2 Z3 G01 X4 Y2 Z3 G01 X4 Y2 Z5 Becomes: G01 X1 Y2 Z3 G01 X4 G01 Z5 I didn't see a feature like that on the web page. Thanks! -Jeff
__________________ www.JeffAlbro.net/cnc/ |
#11
| this version still has dxf import problems.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#12
| Scott, Could you take a look at the G98 (Initial Point Return) and G99 (Reference Point Return) for the Milling Canned Cycles. It doesn't seem to respond. This is used to jump over and clear Clamps and Fixtures with different Z Levels. Thanks!!!!!
| NCPlot to DNC | thardy | NCPlot G-Code editor / backplotter | 3 | 10-02-2006 07:04 AM |
| Need Help NCPlot V1.1 | Switcher | NCPlot G-Code editor / backplotter | 3 | 07-14-2006 04:40 PM |
| HELP W/ NCPlot | MicoMachine | General CNC (Mill and Lathe) Control Software (NC) | 1 | 01-28-2006 03:48 PM |
| NCPlot v2 beta 12 now available | MetLHead | NCPlot G-Code editor / backplotter | 4 | 08-20-2005 09:23 PM |
| NCplot V2 | CNCadmin | NCPlot G-Code editor / backplotter | 6 | 04-21-2005 12:10 PM |
