Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > NCPlot G-Code editor / backplotter
NCPlot G-Code editor / backplotter Discuss NCPlot software here.
Old 03-03-2007, 07:40 PM
edo edo is offline
edo is on a distinguished road
Problems converting DXF files
I've been using the trial version and have had great success with simple files that I've drawn in TurboCAD, but I just can't seem to figure out what's going on with this file. This was created in Adobe Illustrator on a MAC and saved as a DXF file. I moved the file to my PC and was able to open and edit it in TurboCAD, but when I bring it in to NCPlot, I don't get the whole image and parts of it are mirrored. Here are screen dumps of TurboCAD and NCPlot. Any suggestions? Thanks.
ID:	32880   Click image for larger version
Old 03-03-2007, 07:54 PM
MetLHead's Avatar
Gold Member
MetLHead is on a distinguished road
If you can post the DXF file, I'll have a look at it.
Thanks,
Scott
Old 03-03-2007, 08:35 PM
edo edo is offline
Thanks for the offer, but the file is 2.4MB, too big to upload.
Old 03-03-2007, 08:37 PM
MetLHead's Avatar
Gold Member
You can also send it to my email, file size shouldn't be a problem:
scottmartinez@ncplot.com
Thanks,
Scott
Old 03-03-2007, 09:10 PM
MetLHead's Avatar
Gold Member
Ed,
I had a look at your file and noticed a couple of things. First, this file contains block instances, which NCPlot doesn't like. Try exploding (or whatever you call it in TurboCad) the drawing so that it doesn't contain any blocks. Secondly, this showed some mirrored objects when I loaded it into Rhino, so it might be the way TurboCad is saving it. If possible, save it as an R12 or R14 DXF file and try loading it into NCPlot again.
Thanks,
Scott
Old 03-03-2007, 09:39 PM
edo edo is offline
Thanks for looking at the file for me. I "Exploded" everything and found some 'Block Insertions' that I converted to Polylines. Still no luck. TurboCAD doesn't have options for different types of DXF files. I'll have to wait until tomorrow to look at this again.
Old 03-03-2007, 10:12 PM
ger21's Avatar
You might want to try using the .dxf converter at www.a9tech.com to convert it to an older version. And also, you can ususally zip a .dxf file down to a much smaller file size.
COnverting 2D images to 3D cutting files Salty72 Coding 34 01-15-2008 02:15 PM
converting MC files to DXF Sprew Mastercam 1 11-04-2006 12:18 PM
Mach3 converting dxf files problem randyf1965 DIY-CNC Router Table Machines 7 04-19-2006 12:28 AM
converting blueprints to DFX or AUTOCAD files toolmkr13 General CNC (Mill and Lathe) Control Software (NC) 3 07-13-2005 12:14 PM
converting to dfx qsacracer G-Code Programing 31 04-26-2005 04:43 PM
